Denso SC20HR11 spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Jul 12, 2020.
  1. AzusaPrius
    AzusaPrius Senior Member
    1,875
    822
    These are what I removed out of my prius when I swapped out the plugs.
    Assuming they are original and since there is no service history by toyota having changed them, I will say these have 160k* miles on them as that was around the mileage when I took them out.
    They are said to last 100k.
  2. AzusaPrius
    1,875
    822
    jzchen likes this.
  3. Tande
    Tande Active Member
    502
    302
    Mich.
    Send them to me........I'll get another 100,000 out of them! ......:)
    Fostel and 2012 Prius v wagon 3 like this.
  4. Mendel Leisk
    38,717
    Maintenance schedule says 120k miles (or 12 years). Too, the recommended replacement Denso plug is now slightly hotter: in the part number the 20 became 16.
    AzusaPrius likes this.
  5. High Mileage
    High Mileage Active Member
    135
    231
    2018 Prius Prime
    I was able to get 192K out of my first set of plugs on my 2010 before I started getting a misfire under load. I purchased a new set of the Denso plugs from Ebay or Amazon. (Its been long enough that I forget which) They came in boxes that looked authentic and the plugs looked authentic to my eyes anyway. The second set lasted only 70K miles before I started getting a misfire again under load. When I pulled them out the center electrode was almost gone. I believe they were not authentic Denso plugs. Your plugs look like they have been around the block a few times but not bad for 160K miles.
  6. AzusaPrius
    1,875
    822
    I always replace the plugs after buying a car but yea they dont look bad and I will keep them as back up.
  7. johnHRP
    johnHRP Active Member
    417
    133
    tally, fl
    In USA it is 120k miles schedule, in Europe 60k miles since European not get used to long reliability of Toyota cars. European cars broke down much easier. After checking mine at 60k miles, I put them back and check it again at 100k miles, it is still really good.
    Fostel likes this.
