Depleted traction battery
Discussion in 'Gen 3 Prius Technical Discussion' started by Ikie, Dec 29, 2023.
  1. Ikie
    Ikie Junior Member
    Cape Town, South Africa
    My car wont start and I have replaced the auxilary battery. The engine doesnt start so I assume the traction battery is depleted. How can I charge the traction battery from an external source?
  2. Tombukt2
    Tombukt2 Senior Member
    8,943
    1,557
    Durham NC
    If that's the case you'll have codes dash lights on let's maybe read the codes and see what you really have Do you have a DVOM or vote meter You can get access to some terminals and check your battery voltage I've had them sit a long time and start right up just put in the 12 volt in them because they were dead I mean I just picked up a car but sitting almost a year put a 12 volt in it and a car started right up engine running I was amazed More shocked so maybe get the codes see what you have.
    49,397
    there is a battery charge icon on the dash. you can charge it with a grid charger if necessary, but ar 19 years, it might not work.
  4. ASRDogman
    ASRDogman Senior Member
    6,063
    3,259
    Prolong Charger.... But, you can use a volt meter to check the voltage.
    You'll have to remove the cover of the hybrid battery. All pretty simiple.
  5. Ikie
    Ikie Junior Member
    I found the issue. The orange safety plug/switch was not seating correctly. After resetting the plug
    , she started right up but the engine was idling rough and misfiring but as she warmed up it became smooth again.
    Thanks for the advice and replies. Much appreciated.
  6. bisco
    49,397
    congrats, well done!
    how did the orange safety plug become loose?
  7. Ikie
    Ikie Junior Member
    I can only assume that while removing the spare wheel, it somehow dislodged but Im not really sure.
