Depth of 2 DIN Slot
Discussion in 'Gen 3 Prius Audio and Electronics' started by tariq_niazi, Feb 18, 2013.
  1. tariq_niazi
    tariq_niazi Junior Member
    Culver City, CA
    I am planning on replacing the radio in my 2010 Prius II with an aftermarket navigation unit.
    But I am not sure about the depth of the 2 DIN slot.
    Can anyone advise where I can find out or have anyone measured the depth of the 2 DIN slot.
    Any help will be greatly appreciated.
    Thanks!
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    single DIN (180 x 50 mm panel) or double DIN (180 x 100 mm panel) size. The depth is not standardized!
    You need to figure out the depth of the device you want to install, then find the Double Din unit that fits your needs!
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Are you referring to the depth of the hole in the dash? There is a lot of room in the dash for just about any receiver. follow the A/V upgrade link in my signature and there are some pictures of the dash.
