Desperately need help diagnosing my 2008 Prius (red triangle, limp mode, ABS/VSC/TRAC lights)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by b0814, Jun 2, 2026.
  1. b0814
    b0814 New Member
    Charlotte, NC
    I own a 2008 Prius with 280k miles. Over the past 6 months, I have been getting intermittent red triangle every month or two. Initially, I had code P0A80 but I cleared it and it hasn't come back since. I have also replaced the inverter coolant pump after it failed and blew the AM2 fuse mid-drive. Fast-forward to last week, I had been driving with no issues for months when suddenly I lost all engine power and all the dash lights came on (ABS/VSC/TRAC, red triangle, red "main" battery icon on the MFD).
    I was able to coast into a gas station where I unplugged the 12V battery and the car went back to normal, at which point I drove it straight back home and scanned the codes using Techstream. The red triangle did come back on, but only after idling for a while in my driveway. Initially, I couldn't get the engine to start after turning the car off and back on, and it was giving codes P0A0F and P2103, but I cleaned the throttle body and that seems to have fixed the issue. I did check the hybrid battery just to be safe, but it seemed ok and wasn't throwing any codes. All block voltages were within 0.3V under load and resistance values were consistent across all blocks, though they were a bit high (30+ milli-ohms at times).
    In addition to the engine codes, Techstream showed C1319 under ABS/VSC/TRAC relating to the Changeover Solenoid. I believe it briefly showed C1247 (Stroke Sensor Malfunction) as well, though I could be misremembering. I thought the issue might be with the brake actuator since I was hearing the pump activate pretty frequently and it's been making the characteristic honking sounds for at least a year. Probably a dumb idea in hindsight, but I decided to perform a Linear Valve Offset hoping it might fix the issue at least temporarily if it is indeed the problem. The offset didn't complete, it stopped halfway through but the techstream timer kept running. I scanned the codes again when I was done and the C1319 code was gone. In its place was C1345 and C1368 which I have been unable to get rid of. I tried multiple times to get the calibration done, even hooked up a charger to the 12V battery, but every time it would stop with 40 seconds or so remaining.
    My regen brakes are now completely disabled since there is no calibration and the ABS/VSC lights are now permanently on. I have inconsistent braking power, a hard pedal, the rear brakes are binding and I hear a clanking noise whenever I slowly release the brake pedal after turning the engine off; like a 5-gallon bucket being dropped on the ground but quieter and more muffled. Before the failed LVO, the brakes still functioned just fine even if they were noisy. Anyway, I'm afraid I may have ruined any chance I may have had at any fix that doesn't involve shelling out thousands for a brand-new actuator. Any tips or advice would be greatly appreciated. This is my daily driver and I'm unfortunately really strapped for cash right now. Should I try bleeding the system? I'm really desperate here.
  2. saneesh8
    saneesh8 Member
    226
    Allen, TX
    Regarding the inverter coolant pump, i hope you used the OEM one from a dealer and not aftermarket / counterfeit one. The throttle body codes, looks like a loose connection or short ? Anyway it is good now.
    Unfortunately, It looks like you have to replace the brake actuator. All the symptoms are pointing to this. It is $1360 at a local dealership. From what i read, used ones are hit and miss. Also replacing this is at least 1/2 day job. I replaced mine when it started making sound every 10 seconds consistently. There was no codes, just replaced it because my teenage son is driving it. I think It was 200$ less back in 2024.
    I am not an expert, but can you try to flush the system with new fluid and bleed procedure with the software again?
  3. Tombukt2
    Tombukt2 Senior Member
    13,720
    2,483
    Durham NC
    It's about 3 hours it is hit or misse with used but if you get the right part number more Hit than Miss
  4. ChapmanF
    18,848
    On the bright side, the red triangle this last time was probably just because of the P0A0F—simply a code acknowledging the engine issue, not any separate hybrid-system issue.
  5. b0814
    b0814 New Member
    Charlotte, NC
    Yes, I bought an OEM part straight from the dealer so there definitely shouldn't be any issues with it. I've resigned myself to the fact that the actuator needs replacing. I made a last ditch effort to calibrate the module and it failed again, this time the usual C1345 and C1368 codes were accompanied by C1256 (Accumulator Low Pressure), so now I'm sure of the issue. I'm debating whether I should try pulling one from a junkyard Prius for $100 first, they offer warranty but I don't know if it would be a waste of time or not.
  6. saneesh8
    saneesh8 Member
    226
    Allen, TX
    If you can get it from a low mileage car, would be ok i think. The line on the top can be a pain to align when installing. Go slow. Also when you have the inverter out, check the engine mount under it. Also the valve going to the heater core, remove and clean it. Flush the heater core while you are there. I regret not doing this while i was replacing the actuator. Good luck.
