Detailed Prius Specs
Discussion in 'Gen 2 Prius Fuel Economy' started by melephant, Jun 18, 2005.
  1. melephant
    melephant New Member
    Somonauk, IL
    I want to be new wheels but lighter ones for sure. Hence, I need to know how much my stock 2005 wheels weigh. Can anyone help me find data like that? :p
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Stock (US) Prius Wheels
    Weight: 6.5kg
    PCD 100mm
    5 Holes
    Offset 45mm
  3. HYACK
    HYACK New Member
    110
    Cape and Islands, Massachusetts
    mel, cze?
    I think the entire stock wheel tire weight = 35 lbs?
    I don't think you can find to many more 15x6 wheels on the market, period.
    But if you want to upgrade to a larger size, such as a euro 16" or other 16" or even 17" you should expect to add at least 4 lbs per wheel/tire. And budget for possible 8-9 lbs per wheel/tire.
  4. melephant
    Somonauk, IL
    The wheels I looked at where 14.6 lbs. and 15 X 6.5's and they support the stock tire size. You also knew more about the Prius charging system than I did. Is there a source I can get my hands on get info like this, so I don't have to bug you guys?
  5. Technogeek
    Technogeek New Member
    142
    Seattle, WA
    The factory Goodyear Integrity tire 185/65-15 weighs 17 pounds according to TireRack.com:
    http://www.tirerack.com/tires/Spec.jsp?mak...rtnum=865SR5INT
    Not sure if that means 16.5 rounded up or 17.9 rounded down. It could be anything in between.
    So that means the factory wheel (14.33 pounds) + tire (17 pounds) = roughly 31.33 pounds.
    If you are interested in changing the wheels and/or tires, be sure to consider the weight of your new purchase in order to maximize MPG.
