Details on EPA test of Volt & Leaf : Response to FOIA Request
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by evnow, Jan 20, 2011.
  1. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    There have been some threads here about the EPA numbers for Volt & Leaf. So, this may be of some interest here.
    http://www.mynissanleaf.com/viewtopic.php?f=4&t=2433
    Smidge204 filed for information on how exactly EPA tested and calculated the figures we see on the labels of Leaf & Volt. He got the requested information and the files are posted in the link above.
    Bottomline, they used the 30% fudge factor - just like they do for all ICE cars. That is how they got 73 miles for Leaf and 35 for Volt.
    2 people like this.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Thanks for posting. I will digest the information tomorrow.
  3. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    Good information. With the test the way they are I think we need to use a fudge factor. That said they really need to revise the tests so that a smaller safety factor is used. On hybrids the big eye opener for me was short trips, and how much that deteriorated my real world mileage. On EVs guidelines that should be published to show the effects of heat and air conditioning in the test. For everything we should have test runs that more closely move where Americans ride. 35miles and 73 miles are good ev ranges for many drivers, and the important thing is that consumers get good information.
  4. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Some interesting info I dug out.
    Interior Volume (including Prius for comparison)
    Prius: 93.7 Passenger + 21.6 Luggage = 115.3 cu.ft.
    Leaf: 90 Passenger + 23 Luggage = 113 cu.ft.
    Volt: 90 Passenger + 18 Luggage = 108 cu.ft.
    Since Midsize is 110 to 119 cu.ft, both Leaf and Prius were catagorized as Midsize and Volt as Compact. I thought GM said Volt's luggage volume is 10.6 cu.ft.
    Battery Capacity
    Leaf: 360v x 66 Ah = 23.76 kWh
    Volt: 348v x 45 Ah = 15.66 kWh
  5. hill
    8,177
    If the Volt goes 35 miles electric and the Leaf goes 100, How can that be? You'd think that either the volt would be less than 11kWh or the leaf would be over 30kWh ... even after factoring the weight disadvantage of the Volt's ICE.
  6. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    EPA range for Volt is 35 miles and Leaf is 73 miles. Leaf is also more efficient (34kWh per 100 miles) than Volt (36kWh per 100 miles). Leaf utilizes the battery with wider SOC window also.
  7. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    How is the "fudge factor" calculated?
    The documents in the link suggest that it can be "up to" 30%.
    If I remember what I saw on EPA pages giving raw and adjusted test numbers, the percentage really does differ from car to car, and the percentage difference between raw and adjusted numbers seemed high for the Prius (I guess about 30%).
    Why are they different for different cars?
    Thanks to whoever can answer!
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    If you download the a datafile from Download Fuel Economy Data, the unadj columns are the numbers prior to being fudged.
    The article I linked to from http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html talks about about the old 10% fudging down for city and 22% for highway but then in 08, more test cycles were added.
  9. kgall
    kgall Active Member
    984
    152
    The Car and Driver article is pretty good, but it doesn't say how the fudge factor is calculated and why it might be a bit different for each vehicle, as it appears to be from a quick glance at the EPA datafile. (OR am I wrong about that??)
  10. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    I can't speak to the "a bit different for each vehicle", but prior to model year 2008, it was a straightforward 10% downward for city and 22% for highway. It's mentioned at Fuel Economy - On-road Vehicles and Engines | Cars and Light Trucks | US - EPA and EPA's Fuel Economy Programs | Fuel Economy | US EPA.
    I think for MY08 and beyond, it's more complicated since per EPA's Fuel Economy Programs | Fuel Economy | US EPA
    For example, I don't believe the 08 and 09 Priuses were retested w/the 5 tests and were just adjusted by formula.
    If you download the 07 datafile and do the 10% and 22% adjustments to the Prius, you should arrive at the right sticker (for the time) 60 mpg city and 51 mpg highway numbers. I did and it should hold true for all the cars there.
  11. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    I like the Leads efficiency over the Volt but do not like the wider SOC window and even worse the lack of an active battery temperature management system.
    The Volt not only can heat its battery but it has a better cooling system as well. I still trust the Leaf but I think there will be more warranty issues with the battery. Thankfully the warranty is eight years on both and I do think that is enough.
  12. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    Leaf does have active cooling like Prius. It is air cooled.
    Volt does have liquid cooling because it uses the battery pack twice as hard as the Leaf! Volt has more powerful electric motor to move more mass (gas powertrain gets free piggyback ride) and smaller battery. Therefore, it is forced to use narrower SOC.
  13. Trollbait
    11,555
    Little has come out yet, but the Focus BEV is supposed to have an active heating system for its battery like the Volt. Keeping the battery at the preferred temperature while charging allows the battery to more efficiently accept the charge and reach full capacity.
    Nissan choose to go without an active heating system to cut costs, and I suspect to get to market sooner.
  14. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    But Nissan does have better batteries. Rumor is that next gen LG batteries won't need active thermal management.
    According to Nissan that was to save space - and Nissan will have a col weather trim with warming blanket.
