"Detour" function in Nav System
Discussion in 'Gen 2 Prius Main Forum' started by journeygirl1, Apr 26, 2005.
  1. journeygirl1
    journeygirl1 New Member
    [font=Arial:17c604675b]I was traveling down I-65 yesteday where I could see stop & go traffic ahead. I decided to try with the "detour" function in the NAV system. I pushed the "talk" button, said "Detour," and the car said "Detour to destination?" and I tapped "Yes" on the screen. THEN NADA
    -=Amber=-
    2005 Silver #6
    [email protected]
  2. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Good to see you again JourneyGirl!
    I have used the detour function, but not with voice command, and not to destination. Instead, I used the 1 or 3 mile detour. If it could find an alternative, it would, and if not, would tell me it couldn't. I don't remember which button at the bottom of the map would have the detour option.
  3. yoda
    yoda Member
    116
    San Diego, Ca.
    Why would anyone NEED "detour"?
    When I deviate from the computers course, the nav system re-maps automatically. I thought that was the coolest thing the first time I saw it.
    8)
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Belle can be real stubborn sometimes when I change the route. It does all sorts of things to get me back on the first path. Doing the 1-3 mile detour lets the system use a new route.
  5. DanMan32
    3,799
    26
    Tampa Bay, FL
    I've had little trouble with reroute.
    Detour is great when you are in a jam, and know that there are few crossroads that will get you to parallel roads, or even which parallel road is best.
  6. scwolfe
    scwolfe New Member
    I have used the Detour feature three times thus far, each time it worked flawlessly. However, I have never done it with voice control. If I recall correctly, as the NAV system is not in front of me. I push route, then detour option, it asks me how many miles from a preset menu. I have tried the 1.5 and I think 15 mile options thus far. It immediately told me which exit to take, and directed me down roads I would never have thought of taking in areas I have never been. It has saved me probably a couple of hours of torture to date, as I have not had to sit in bumper to bumper traffic on the Garden State Parkway and the NJ Turnpike.
    So I guess I am saying, try it with the menu and touch screen instead of voice command.
    Steve
  7. Hatfield
    Hatfield New Member
    91
    San Diego, CA, US
    I've used it three times, all when stuck in LA/Inland Empire traffic, and it worked for me as well. Same here - push ROUTE then DETOUR and I think I tried the 5 and 15 miles detours.
    Martina (short for Martina NAVratilova) told me to get off at the next offramp, put me on some surface streets. One of the times I was on a road parallel to the freeway and I could see the logjam, so I got back on myself, and she adapted perfectly. The rest of the time I followed her suggestions, and I'll be damned if she didn't save me 20 or 30 minutes. I thougth - this is great... until everyone else has one too!
    I think the big difference between "detour mode" and "regular mode" is that in regular mode, Martina has established a preferred route, say it's the freeway, and most of the time she'll try to get you back onto the freeway if you deviate. In "detour mode" she knows that you're trying to avoid the freeway, so if you deviate from even her new prefered route, she might try other things but she won't try puting you back on the freeway.
    Sometimes, though, if you're in the middle of B.F. Nowhere, the Detour function just doesn't work because there is no other way to get there.
  8. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    I do detours about once a week with Seattle's I-5 traffic. I will try today with the voice commands to see how it goes. Most of my problems with voice have been due to highway road noise, but I'm just not talking loudly enough.
