Devastating loss in my household
Discussion in 'Fred's House of Pancakes' started by naterprius, May 14, 2005.
  1. naterprius
    naterprius Senior Member
    1,843
    Suddenly, without warning, I have suffered a devastating loss. I ask all Prius Chatters to mourn with me while I suffer in my sorrow.
    Not the death of a friend, nor damage to my Prius, but I have felt physically ill since last night.
    Not a housefire, but almost as devastating.
    That's right, I'm talking about complete, total, unrecoverable, catastrophic hard drive failure.
    Last night, while looking up recipes online with my company-issued Dell Latitude D600, I leaned on the left wristrest with my wrist (that's right, the WRISTREST) and heard a strange grinding sound. I immediately stopped typing and lifted my hand. I thought for sure I had squeezed the casing and come down on the cooling fan.
    In actuality, the little bit of pressure squeezed through the case of the Dell laptop, through the Dell shroud for the hard drive, through the casing of the Fujitsu 60GB 2.5" laptop drive, and down onto the rotating platter.
    The grinding sound stopped when I lifted my hand, but a new, regular, loud click was eminating from the drive. The next thing that happened was the laptop rebooted, or tried to. The BIOS then reported that there was a disc read error. (Not Windows, but the BIOS). (Getting sicker).
    The next reboot yielded a horrifying error:
    "System disc not found. Insert system disc."
    The hard drive was emitting the awful click, over and over, this whole time.
    Subsequent tries to read data have yielded nothing. To make the story short, I have tried every conceivable technique short of cracking open the sealed casing of the drive.
    It appears to be a total loss.
    I am still dumbfounded that neither the laptop (the wristrest area!) nor the hard drive casing was strong enough to withstand just a little bit of pressure.
    I am consoling myself that at least my Prius is still safe in the garage, but this laptop was only a few months old, so I had been lax about backups. I have never lost a hard drive so quickly in my life.
    Ugh.
    Nate
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    My condolences.
    Depending how desperate you are to recover your data, it can be done by specialists who charge an arm and a leg.
    Here are the results of a Google search for Computer hard drive data recovery service.
  3. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    sry bout ur loss......
    I've NEVER backed up a hard drive.........! What does one use to back up a 80 gig drive?
  4. Tideland Prius
    16,445
    a 120GB hard drive :p
    Sorry about your loss. Yikes!
  5. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Just dump a copy of your data/music/video files to DVD. Recordable DVDs are down to only 40 cents. DVD recorders can be found on sale for $79 (internal) and $129 (external).
    Software is simple to backup too. Just buy a copy of Norton Ghost. It will allow you burn directly to DVD.
  6. tag
    tag Senior Member
    2,526
    Chicago
    I'm really sorry to learn about this situation. First because of your own loss and second because my son will be starting college in August and the Latitude line is what the IT department at the school recommends. In fact, the D610 is what they'll be purchasing from Dell and packaging for sale to students. Sheesh!
  7. Godiva
    Godiva AmeriKan Citizen
    10,339
    You have learned a valuable lesson.
    Just because a laptop is new is no guarantee. The harddrive can last a month, a year or more. The harddrive in my Mac Performa went 6 years before it failed.
    The slim harddrives in laptops are a bit fragile. I back up my titanium regularly. I've had to replace the optical twice already. Once straight out of the box, the second time after two years.
    Yes, you back up regularly. Get an iomega 120 gig external.
    CDs and DVDs are so cheap now it's cheaper and easier to burn a backup.
    You live and learn.
    And I bet you'll never do that again.
    And no, they aren't really designed to lean on.
  8. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    Another alternative, and one I prefer for ease of use: another hard drive of equivalent size, in an external USB case.
    Here's my backup plan for my home PCs:
    • Every two weeks, backup all working files -- documents, Quicken files, e-mail, etc. -- into a ZIP file, and burn it onto a CD-RW. (Obviously, DVD-RW works even better.)
      I do this in batch format, using WinZip's command line utility. Just keep a list of directories I want backed up.
    • Every 3 months, I back the entire drive up onto the external USB drive. (USB 2.0 is rather helpful here. :) )
      The idea is that, in case of catastrophic hard drive failure, I can restore an image that is < 3 months old, and then reinstall what few applications have been installed since then.
      • This works well for me, based on the way my computer is laid out. Your mileage will vary.
  9. popoff
    popoff New Member
    560
    western NC mountains
    Western Digital makes a very nice USB hard drive from 80 gigs and up. It comes with back up software. I bought my 80 gig unit on sale at Circuit City for around $90 with rebates. Easy to use and hopefully reliable.
  10. john1701a
    12,797
    5,280
    57
    DVD is more durable. A layer of plastic protects the data side, rather than leaving it exposed like on a CD.
    DVD is more reliable too. There is better error-correction.
    As for using RW, it's not the ideal choice... since it does have the exposure of being erased. Reusing a RW later isn't the best either, since someday you may want to recover an ancient backup. R is permanent, making it immune to virus attacks. They have a longer shelf-life too. Spending the 40 cents to have that instead could pay off later on.
  11. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(john1701a\";p=\"89700)</div>
    [/b][/quote]
    I agree absolutely with you, John, if I'm archiving files -- i.e., storing them for an indeterminate amount of time -- as opposed to temporarily backing them up.
    But my backup scheme is basically keeping the document backups in ZIP files around for no more than 4-5 weeks -- basically a rotating number of CD-RWs. I erase the oldest CD-RW (and its backup files), and overwrite it with the newest backup.
    I neglected to mention that every 3 months, I make an epoch archive of the current backup ZIP file -- on CD-R, just as you suggest. Those are for archiving, and CD-R or DVD (as you point out, the latter is better) is the choice there.
    My fault -- I should have explained things better. And I am planning on switching to DVD soon, and moving my archived data from CD-R to DVD.
  12. naterprius
    1,843
    Yes, I have no excuse for not having backed up the HDD. I don't know if I can emphasize just how little pressure was actually placed on the casing; it was within reason of what you might expect for a wrist rest.
    Part of my laziness was the fact that I had been waiting to get a DVD burner from Dell until they released dual-format drives (last month) and I needed to put in a requisition with work to pay for it.
    Also, SMART technology should warn the user when the hard drive starts to wear out (as bad sectors increase).
    Also, I figured that I wouldn't lose EVERYTHING. Typically, a dying drive can be somewhat recovered as it's dying.
    Anyway, none of this counts for anything.
    What got me in the end was something that blind sided me; a way to kill a hard drive that was totally unexpected.
    Backup early, backup often.
    Nate
  13. GAGendel
    GAGendel Junior Member
    59
    New Jersey
    I think everyone learns this lesson too late. Fortunately I have a server that runs a daily backup using rsync. I keep a 2 week backup history.
    Rsync is nice (from the developers of Samba) because it only copies the files that were changed (incremental) but always has a complete snapshot of the entire filesystem (using links).
    There are a few other things I do:
    1) Keep all my install CDs together.
    2) All downloaded program installers I keep backed up on the server, along with documentation (SN, etc.)
    3) Keep a list of installed programs and a blurb on what they are.
    These keep me from hunting all over my house and thumbing through 100's of CDs for the install information in the event a catastrophe occurs.
    DVD backup is nice, but with < 5 Gigs per disk this can get really clumsy to backup several 100 Gigs. I'd prefer to use an external HD (firewire or usb) as a quick recovery.
    BTW, I just had the opportunity to use the Backup program built into WinXP, and although it creates an image in it's own format, it's not too bad. The stupid thing is that it wants me to put the catalog on a floppy! Not too many new machines coming with these installed. You can skip this step and it works fine.
  14. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    PS The way I ended up with my current backup scheme is because my previous 2 backup schemes came up short when a problem actually occured.
    Just wanted to point out that disaster was my primary teacher, too!
  15. ALoLA
    ALoLA New Member
    113
    Southern California
    I feel your pain. I've gone through two unrecoverable disk crashes on my Dell's at work. I heard the clicking soon before they died as well. So if you hear clicking sounds, backup ASAP.
  16. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    SO......my dell has the old usb...1.0?.........What should I go out and buy right now to back up with?.......John suggested a DVD drive and Norton Ghost!
  17. naterprius
    1,843
    So, it turns out I have already gone through all five stages of grief:
    Denial: "That sound must have been the fan, not the hard drive..."
    Anger: "Stupid Dell! I can't believe the case is made so thin and cheap..."
    Bargaining: I offered the disk drive gods weekly backups in exchange for just one last boot up with the drive...
    Depression: I posted my woes here on PriusChat.
    Acceptance: I've got a new drive already on the way, I may have my laptop back by tomorrow, fresh and new.
    Anyway, thanks for your support.
    Nate
  18. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(bshef\";p=\"90217)</div>
    Before getting a USB 2.0 card (about $25), I actually backed up the drive images to the external USB drive over USB 1.1. The key word is, overnight.
    Which isn't that much of a hassle. Start it at 10 PM, go to bed, wake up next morning, disk image has been copied to external drive.
    (I use a Norton Ghost-like product, Drive Image -- which come to think of it, was bought out by Norton.)
  19. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    wow what a cheap POS if leaning on it destroyed the hard drive... of course some jobs (like mine) would definitely go with the cheap stuff. i can stand on a regular hard drive and not hurt it. kinda makes me wonder. the hard drive in my laptop has a metal case on it but its ancient...(my laptop also weighs about 10 pounds!... guess that is why im in the market for an upgrade)
    as far as backups, an extra hard drive is so pathetically cheap these days, its faster, no disc change, if i have to swap a disc on backup then it aint for me since my backups only happen in the middle of the night. i should be more diligent on my backups...(if i was, my incrementals wouldnt be so big and i could put them on a CD like i should be doing...) but i am backing them up to 3 different physical drives so im not too concerned with losing anything and i like my setup...totally labor free. (i should verify a copy though...last time i did that was about 2 or 3... or maybe it was 6 months ago...)
  20. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    MAXTOR
    I just purchased this!
