Diag Needed for Traction Battery
Discussion in 'Gen 2 Prius Technical Discussion' started by orprepus, Jul 21, 2016.
  1. orprepus
    orprepus Junior Member
    Hi any and all advice is welcome.
    2005 160K - Red Triangle - P0A80 only code.
    Pulled battery and just test on a multimeter the voltage of each module.
    Ends were at 7.88V rest at 7.95V-7.93V and one at 7.66V.
    Think I have one suspect module at 7.66V and also the concern the invert is over charging?
    Will do a load on each module this weekend.
    Thank You
  2. JC91006
    16,673
    8,518
    When you pulled the codes, what other codes did you get? You should get a code letting you know which block is "weak or failed"
