Diagnose cluster: misfire, surging(?) and codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tanethomas, Jun 25, 2020.
  1. tanethomas
    tanethomas Junior Member
    Tasmania, Australia
    Hi all, I need some help with my 2010 third gen.
    First problem, hard acceleration pulled a p0304 (cyl4 misfire) and p3190 (I assume poor power). Pulled the manifold and cleaned it, then the knocking started.
    Sat for a week, thesis to write. Pulled injector 4 (inc intake up to throttle body for space), gave injector a squirt with some carby cleaner (not a proper clean by any stretch) reinstalled, went for a roll. No difference, knocking, difficult, rolled straight to auto shop, bought injector cleaner.
    Dropped enough in the tank with 1l of fuel, burned up and down a big hill several times. Checked OBD, pulled:
    P0304 (but it hasn’t come back since, perhaps cleaner did the trick?)
    P0701 - too lean
    P0401 - insufficient exhaust gas recirculation flow.
    So, I burned up the highway a bit more, especially along some massive hills, then the engine started - and I don’t know what the correct terminology is - hunting? Surging? It would just softly bounce off the rev limiter, probably 3-5k in 2 second cycles.
    It’s still a bit rough at idle and starting up to push off. If I stop, sometimes the engine doesn’t which is completely out of character. Position into ‘N’, no aircon, engine stops as a rule. Not now, sometimes just keeps running for a minute. If I accelerate hard and it feels like doing it, the engine will start it’s bouncing. Poor student, please help.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Did you just clean the I take manifold or the entire egr circuit?
    How many miles do you have on your Prius?
    Could the fuel pump be the issue (I preventatively replaced ours at 199k miles and the pumps Inlet filter had plenty of sediment in it)?
  3. Mendel Leisk
    38,711
    How many miles on it?
    Have you checked engine coolant level in reservoir?
  4. tanethomas
    Tasmania, Australia
    thanks. 450km/280mi. I cleaned the egr cooler about 20k ago, cleaned the pipe and manifold together this time as well.
    Can I test the fuel pump before I remove it?
  5. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    The only way I know of to test the fuel pump is to "T" into the fuel supply line to insert a pressure sensor, then see what the pump is capable of.
    At that mileage, you maybe dealing with several things, but I'd check the complete egr circuit, coolant level for the engine and look to swap the fuel pump out if you want to keep your Prius for many more miles.
  6. tanethomas
    Tasmania, Australia
    Would low fuel pressure explain the knocking and ‘surging’ problems?
  7. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    If you are getting P3190, one of the causes is lack of fuel;).
    As to the cause of lack of fuel:whistle:.
    Good luck and keep us posted(y).
  8. tanethomas
    Tasmania, Australia
    Ok so an update on my ex taxi with 440,000kms. I went though this car and changed the fuel pump, injectors, spark plugs, cleaned manifold, cleaned egr and valve, tried a bottle of liquid head gasket, new mass airflow sensor, nothing worked. Was PCV. Is now throwing a P0420 code so I’ll go down that rabbit hole starting with the front O2 sensor.
    My PCV symptoms were rough idle, almost refusing to shut off, and the engine just revving in this weird 2 second cycle where it would bounce up to the rev limit and back down to about 3k. This would happen until up to temp and would drive fine enough when driven gently around town but if I went on the hwy, off we’d go again.
    Now chasing the O2 issues because fuel consumption is bad and the P0420 code is up.
