Diagnosing bad battery assembly
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TimStL, May 8, 2020.
  1. TimStL
    TimStL New Member
    St. Louis Missouri
    So I’ve got a gen 3 2010 Prius with 190k miles. Purchased not running. Last owner said he had it diagnosed and it had a bad battery. I identified 3 bad cells. Replaced them and did a 3 cycle balance with Prolong System. The cells seem to be ok, coper plates are clean and wires have continuity.
    when I put it all back in I got the code
    P0B4C
    Hybrid Battery Voltage Sensor "D" Circuit Low
    1. Battery smart unit
    2. HV battery assembly
    I figured the battery control module was bad so I replaced it and got the code
    P0B5B
    Hybrid Battery Voltage Sensor "G" Circuit Low
    Not sure where to turn my attention next. Any advice on this?
