Diagnosing Prius HV Battery (Dr.prius , Torque Pro)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 123omari123, Jun 29, 2023.
  1. 123omari123
    123omari123 Junior Member
    27
    Georgia,Tbilisi
    Several days ago I bought OBD2 scanner - Veepeak OBDCheck BLE+ Bluetooth 4.0, and started to learn its features. I have read lots of threads from priuschat about obd2 and hybrid battery. So, here are some screenshots from obd2 scanner apps about hybrid battery and from ELM327 identifier too.
    I didn't do any battery test from Dr. Prius app or Torque pro , here are only values. Can you tell me is everything ok with my battery or not? As I found out on priuschat and google I think it is in good condition. I think voltage and IR is little increased?! Also, is this misfire number good? I found some info about normal ranges of this values, but is there any official info or chart, e.g. Delta SoC, min/max voltage, volt diff., IR, Pack voltage, blade voltage, temp? I couldn't find what is max charge and max discharge? Also there is fault code P0420. I already replaced the catalytic converter. Where is Bank 1? Prius gen 3 2010, 188000 miles. I know there are so many questions :D
    #1 123omari123, Jun 29, 2023
