diagnosing squeak (audio attached)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jensen, Sep 23, 2013.
  1. Jensen
    Jensen Junior Member
    Asheville, NC
    I can hear a squeak when in motion. Hard to pinpoint from where but seems possibly towards the upper-left. It comes and goes and I've heard it at many speeds, though mainly within 25-45 mph. It's an annoying little sound. Audio of the squeak can be heard in the background (while going ~30mph): prius noise.mp3
    Took it to the dealer and they told me that they never heard the squeak when they took it out to test it (this was before I had the bright idea to record it). So what could it be?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    I don't hear anything but road noise in your recording. Perhaps it is too high pitched to make it through the recording, which is probably limited to speech range frequencies. (My ears are good.) But just as a guess, it is one of the snap in pieces of the dash or pillars. Try pressing on all the plastic bits one at a time to see. My driver side windscreen pillar piece vibrates a bit.
  3. Jensen
    Asheville, NC
    If you listen carefully, it is the high-pitch "jittery" noise in the background.
  4. ernie1
    ernie1 Junior Member
    67
    Sacto,Ca.
    Jenson: Sounds like the noise I HAD in my 2008. It's related to the ac/heater vent on the left side of the dash. It's that silver rectangular thing with the black round knob for controlling the air flow. Just grab ahold of that unit and pull straight toward you and it'll come out. When this happens, look at the arm that is connected to the black round knob I mentioned. The noise is from the connection of the arms/levers. I put very heavy silicone brake grease on this connection and noise has been gone for quite awhile now.
  5. Jensen
    Asheville, NC
    Thanks Ernie! I will definitely check that out.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    upper left
