Diagnosing Toyota Prius 2007. Dtc Codes showing (C0205, C0200,c1300)(c1259,c1310)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Enoch Mease, Jul 20, 2022.
  1. Enoch Mease
    Enoch Mease New Member
    26
    Union Washington USA
    I replaced the battery on my 2007 Prius which has been sitting for a couple years. It starts up and drives a short while until the HV battery drains. So I downloaded Techsteam and got the codes ( C0205, C0200, c1300, c1259, c1310).
    Does anybody know what the combination of those codes could be pointing to? I'm thinking the Skid Control ESU might need replaced?
    I would appreciate what you guys think may need replaced or checked.
    Thank you,
    Enoch
    #1 Enoch Mease, Jul 20, 2022
    51,966
    does the engine run? how far can it go?
    Enoch Mease likes this.
  3. Enoch Mease
    26
    Hello Brisco,
    The engine will run for about 30 seconds and then it dies. The HV battery is down to 1 purple bar now. I would really appreciate your help.
    #3 Enoch Mease, Jul 20, 2022
  4. Enoch Mease
    26
    I did the car scan again and found that the car is now showing C0200, C0205,C1241, C1300, C2318 codes. I'm not sure where to start troubleshooting?
  5. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Which battery did you replace, the 12v or the larger HV?
    FYI : you're moderated until you've posted 5 times.
  6. Enoch Mease
    26
    I replaced both batteries. Thanks
  7. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Best not to try starting the vehicle until you have a better idea of what the issue(s) are.
    Are you sure the vehicle is running for 30 seconds, and not attempting to start/turn over the engine for 10 seconds before it gives up/dies?
    When was your 12v battery replaced or last serviced, and what does the voltage measure when using a voltmeter or multimeter?
    Have you checked all of the fuses inside the cabin (under the steering), and under the front hood near the driver side wheel?
    The factory manual workups below were taken from the older 2004 service manual, and can be a bit dated.
    Here is the workup for DTC C1241 : https://share.qclt.com/丰田普瑞斯原厂英文手册pdf格式/Prius Service Manuals 2004/修理手册/04pruisr/05/21avn/cic12414.pdf
    You may notice in the above workup for DTC C1241 (and some of the other workups listed below), the mention of a "detailed code" (to the right of the DTC). Knowing any INFs (detail codes or subcodes) may help isolate the issue within the workup for a reported DTC.
    Within techstream, click on any bluish snowflake(s) to the left of a reported DTC(s) to find the INF or detail code (sub code) for a given DTC. Not all DTCs (OBD2 codes) will have INFs (subcodes).
    Examples are below :
    Here is the workup for DTC C2318 : https://share.qclt.com/丰田普瑞斯原厂英文手册pdf格式/Prius Service Manuals 2004/修理手册/04pruisr/05/21age/cic2318.pdf
    Here is the workup for DTCs C0200 and C0205 : https://share.qclt.com/丰田普瑞斯原厂英文手册pdf格式/Prius Service Manuals 2004/修理手册/04pruisr/05/21avn/cic02003.pdf
    Here is the workup for C1259 and C1310 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21avn/cic12595.pdf
    Here is the workup for DTC C1300 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/21avn/cic1300.pdf
  8. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Assuming it was the 12v battery, then you should also clean the throttle body (and MAF sensor), unless this was recently performed.
    When you disconnect or replace the 12v, this will reset the learned fuel mapping to the factory default settings.
    How many miles are on the vehicle?
  9. Enoch Mease
    26
    Wow thanks for all the info about the codes SFO. Ok, I won't try to start it again unless I should. I checked all fuses with a test light and they seem to be fine.
    Some weird things are happening.
    I did another health check and now it's just showing P0A80 code. I cleared the codes and did it again and that's all that coming up now. After putting 5 gallons of gas in the tank and it's still only showing one bar. Also, I put it in natural but it won't roll. The 12 volt battery is at 12.16 V. I have jumper cables hooked up to the battery in a different car so that if it starts to go dead I can charge it. The car has 173,000 miles on it and I replaced some cells on the HV battery.
    Thanks for the tip about cleaning the throttle body, I'll do that.
    SFO likes this.
  10. Enoch Mease
    26
    It rolls in natural now. It starts up and runs for about 8 seconds and then sputters and dies.
  11. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Did you do that already? (use a toothbrush dipped in rubbing alcohol or wodka to clean the plate and throttle bore, takes like 15 seconds)
    Do you have MAF cleaner handy?
    The engine isn't actually starting, it is only draining the HV battery while it spins the engine over in an attempt to start it.
    You should have additional OBD2 codes, like P3191 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/2054m/cip3190a.pdf
  12. Enoch Mease
    26
    Okay that's helpful.
    I cleaned the throttle body with rubbing alcohol. I could go purchase the MAF and spray in it too. What do you think I should do to get the engine running? Thanks
  13. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    The MAF spray is for cleaning the MAF sensor, remove the sensor to spray both the 'bulb' and the 'wires'.
    https://priusdiy.com/tutorials/engine/massairflowcleaning.html
    100K maint - 2
    Best to run another scan with techstream, as you should have a DTC for a 'no start' condition. Post the current DTCs in this thread.
  14. Enoch Mease
    26
    I ran three more scans with Techstream and it's still just showing me the one P0A80 code.. ??
    Just to let you know, I have another prius 2005 that I could swap parts if needed.
  15. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Odd that this is the only code being stored, are you doing the 'health check' ?
    If you've cleaned the throttle plate and surrounding bore, and cleaned up the MAF sensor by spraying it with MAF cleaner (links above), then disconnect the 12v to reset the fuel trims again, reconnect the 12v, and attempt to start it one last time. It will take two tries to start since you've disconnected the 12v, the first try offers a bunch of warning lights on the dash, power cycle it off, then try to start it a second time.
    Realize that the SOC for the HV battery on the MFD will no longer be accurate, and will offer you a false sense of hope.
    If it doesn't start, then run another scan to see if you have additional codes being stored.
    bisco and Enoch Mease like this.
  16. Enoch Mease
    26
    It shows that the tank is full of gas but now it won't start. I also sprayed the MAF sensor and bulb like you said.
  17. bisco
    51,966
    you may have to recharge the hv battery. are you not getting any snowflakes for sub codes?
  18. Enoch Mease
    26
    I swapped the HV battery from another Prius and tried starting. The car will only run for a max of 8 seconds now and then a red triangle comes up and dies which means that the engine never started running. Also, I've tried running the health check on Techstream a number of times and not one code comes up besides a air conditioner code now. Is there some trouble shooting I can do to get the engine running? I'm not a mechanic so whatever information would help. What would you do? Thanks for your time.
  19. Enoch Mease
    26
    Ok, I restarted my techstream laptop and did the health check and now it's showing all 4 codes again. C0200, C0205,C1241,C1300.
  20. Enoch Mease
    26
    Is it right to think that I should replace the skid control ESU? I plan on taking apart the dash and replacing it with one from a different Prius. Can I just replace it or is there some reprogramming or bleeding brakes that I need to do? Are there special tools that I need?
