Diagnostic Trouble Codes P0K92 and P0K7K
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Montex, Jul 6, 2014.
  1. Montex
    Montex Junior Member
    Portland, OR
    I have diagnostic trouble codes P0K92 and P0K7K set on my 2008 Gen. II Prius. I have searched the forums and cannot locate these two codes.
    I started and drove my car for several miles today, then it started to run rough. I pulled over, then called a tow truck to tow my car back home. I have a high-level scanner/code reader that read P0K92 and P0K7K codes.
    I have also searched for a list of trouble codes, but have not found a list for my application.
    The car now starts, yet has only two purple bars on traction battery. 12VDC battery is tested within specs for no-load and load conditions. Please advise. Thanks!
    *** UPDATE ***
    The car starts, the check engine light is on, the red triangle light is on, MFD has a small red car icon with a "!" in the middle of it (in the upper-left of MFD), the accelerator pedal does not seem to increase the engine RPM speed.
    #1 Montex, Jul 6, 2014
  2. Patrick Wong
    18,200
    6,474
    Those codes are not valid Prius DTC, so you need a better code reader. Mini VCI is the best available for this purpose since it is a Toyota Techstream clone.
    What trouble lights are on? Any warning messages or icons on the MFD display? If you see any lights or warnings, pls take sharp photos and post.
    Montex likes this.
  3. Montex
    Portland, OR
    Patrick:
    Thank for the info regarding the Mini VCI scanner. I'm not surprised that my cheap scanner is showing bogus codes for my Prius.
    I'm unable to photograph my display and post at this time.
    Car starts OK, but MFD does not indicate any power transfer to/from motor to battery. A/C does work OK.
    MFD has a "red car icon" with "!" in the middle of it, which is present in upper-left of MFD screen.
    "VSC" light is (was) ON on the dash too...
    However, I just went out to start the car and re-observe the indications/icons.
    a. Red triangle is ON.
    b. "Check" engine is ON.
    c. MFD has a "red car icon" with "!" in the middle of it, which is present in upper-left of MFD screen.
    Now, the MFD 'DOES' indicate that charge is going into the battery (This was NOT the case an hour ago) - it showed NO CHARGE path indications on the MFD at all. Hmmm...
    #3 Montex, Jul 6, 2014
  4. Patrick Wong
    18,200
    6,474
    The MFD icon is a serious warning, which shows you the hybrid vehicle system is impaired. You need to have the DTC retrieved to have a clue about what is wrong with your car.
  5. bisco
    49,500
    try auto zone, they might be able to read the codes, and it's free.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Whats the miles and is this car new to you and does it have a salvage title?
    Has your car had the TSB done to replace the Inverter Coolant pump?
    Do you see violent agitation in the Inverter Coolant tank when the car is in ready? If not the coolant pump has failed and severely overheated the Inverter.
    Or:
    The hybrid Battery is failing. First sign is wide swings between charge and empty on the battery
    and the battery fan coming on in the backseat. Constant big hills are very hard on a Prius and I'm sure you have heard the battery fan come on before based on where you live.
    Do not continue to drive the car until the Hybrid codes are pulled. Post them back here.
    Autozone does not use a Hybrid capable code reader. Its either mini vci or $125 labor charge at the dealer to pull the codes. If dealer get the paper readout with all the codes including the 3 digit suffix also:
    XXXX-XXX
  7. Montex
    Portland, OR
    Thanks for the replies...
    Q: Whats the miles and is this car new to you and does it have a salvage title?
    A: No salvage title. I am original owner since new. Car has 186,xxx miles. New Exide auxiliary battery reads at proper specs (It's new installation did not resolve any of my recent problems with the car.)
    Q: Has your car had the TSB done to replace the Inverter Coolant pump?
    A: Yes...The inverter pump was replaced within a year ago. Inverter coolant reservoir does have agitation within, suggesting that the inverter's coolant pump is working OK.)
    Q: Do you see violent agitation in the Inverter Coolant tank when the car is in ready? If not the coolant pump has failed and severely overheated the Inverter. (See above answer).
    I ordered a "Mini VCI" code reader, but it has not arrived yet... My cheap code reader indicates that codes are present, yet reads them as non-standard Prius codes (Note the two codes cited in the title of this thread's OP.)
    As of this morning, I tried to run the car for awhile to 'charge' the HV battery. The HV battery initially showed 4 blue bars, and the Information display showed charge going from MOTOR to BATTERY. Then, after a couple of minutes, the charge flow indicator did not show any charge flow to from MOTOR to BATTERY. ALL charge flows were blank (not indicating anything charging. RED TRIANGLE is ON, and MFD has RED vehicle icon with "!" in upper-left of display. "CHECK [engine]" light is ON. "VSC" is illuminated.
    Given that I do not have a proper 'code reader' for the Prius, I will attempt to seek one out here in the Portland, Oregon area.
    Any additional input is greatly appreciated. Many THANKS to those who have positively commented so far~
  8. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    Is the hybrid cooling fan in the back audible?
  9. Montex
    Portland, OR
    Should a person be able to hear the HV Battery cooling fan ON at all times, or after a certain run time/temperature? Please advise.
    I verified that Trouble Code "P0A92" (Hybrid Generator Performance) is the code that continues to set on my car... I used a 'borrowed' OBDII code analyzer to observe/clear/re-observe. This same code re-apperared after clearing the previous P0A92 code.
  10. Patrick Wong
    18,200
    6,474
    DTC P0A92 most likely means that MG1 within the transaxle has failed. The repair manual suggests that the resistance across the three MG1 stator windings be checked and they should be similar, 0.109 ohm or less (this requires use of a milliohm meter). Then check resistance from each winding to ground, which should be close to infinity, 10M ohm or more.
    It is not normal to be able to hear the traction battery cooling fan running at all times.
  11. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Luscious garage (luscious.com) discusses this and mentions many dealers mistakenly replace the Inverter with this nag when actually it is MG1 that has failed.
    Mountain terrain is the hardest on a Prius as the mg's will require hyper current to power the car to get up and over the mountains. Hyper maintenance of the trans fluid and Inverter coolant will help greatly as the fluid and coolant will be punished with this super duty use of the car especially if the owner drives it like a regular car without a thought of the electrical process involved ie: Don't push the car hard up a mountain if the Hybrid battery is flagged. This under volt over current is what kills electric motors and you will usually smell something burning or the Inverter coolant will be extremely hot. The engine will be racing also. This has left many a Prius owner on the side of the road mounting a huge hill.
    You may have experienced this yourself or smelled something hot.
  12. Montex
    Portland, OR
    Many thanks to all who have weighed-in to help me resolve my Prius issues. Good advice from all.
    I received a "Mini VCI" diagnostic USB-powered scanner tool today. I read the trouble codes that have been set on my car with this device.
    Trouble code P0A7A (Generator Inverter Performance) had been set. I cleared the code, ran the car in my driveway for a time, then the same P0A7A code set once again. Inverter? MG1? Thanks to the previous poster regarding the checking of MG1 windings. My Inverter water pump and coolant has been changed under factory recall within the past year. I do see "turbulence" within the inverter's coolant tank.
    My car is mostly a daily driver, and I have smelled no "burning smell" to date. I resonate with Ed's previous comment regarding low voltage/high current on windings. Sadly, the tranny fluid has not been well maintained, and may have been a factor with my current issue. The Prius has been otherwise fault-free over the past 186,000 miles. I did use the diagnostic tool to observe the HV Battery voltages and resistance readings - the voltages all read to be quite equal. I'm still getting use to the Mini VCI software's user interface.
    I do not have a milliohm meter. I do have a DVM that *may* be able to measure resistance down to < o.109 ohm. However, I do not know where to access the stator winding 'ends.' @Patrick: Can you expand on this for me..as to where I may access the windings to be measured?
    May my issue be a failed inverter? What may be the odds in favor of inverter failure over MG1 failure? I am a newbie at diagnosing Prius issues, but am an experienced (and GM-certified) shade-tree mechanic. Thanks to all for your input and your patience! Greatly appreciated here...
  13. Patrick Wong
    18,200
    6,474
    1. Did the Mini VCI also report P0A92 as well as P0A7A?
    2. If only P0A7A is being reported, then the inverter, transaxle, or hybrid vehicle ECU may have failed. The three digit sub code may provide an additional clue.
    3. Subscribe to techinfo.toyota.com so that you have access to factory repair manual info and the troubleshooting guide provided with the long list of DTC. As a professional mechanic, you will benefit from this and need access especially since your car has a serious problem.
    4. If P0A92 is a current code, you can remove the inverter cover, find the MG1 three-terminal power cable, disconnect it, and use that as a means to measure resistance across the windings. (There are several safety precautions associated with high voltage, itemized in the repair manual.)
    5. Although you don't have the means to precisely measure the stator winding resistance, if there is a problem you should notice a big difference in the measurement of one winding, or may notice a fault resulting in measurable resistance from the windings to ground. Either of those occurrences will be adequate justification to replace the transaxle with a used part from a salvage yard.
  14. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Maybe pull the trans fluid and see how bad it is. Easy 2 bolts. If it smells burnt well there you go.
    Inverter failure has been extremely rare on G2. Trans-axle failure not so rare given your miles and maintenance.
  15. Montex
    Portland, OR
    @patrick:
    Code P0A7A (with sub-code 325) has set, and was read by my new-to-me "Mini VCI" code scanner.
    Thank you for the tip regarding techinfo.toyota.com - I will subscribe, read, and learn more about the procedure to measure MG1 my windings.
    __________
    Other sub codes that set *once* (a day or two ago) were:
    C1310 (ABS/VSC/TRAC)
    B1421 (A/C)
    These two codes set only *one time*, were cleared, and have not returned to date. Do these two additional codes yield any clarification to my car's problem?
    I understand varnish-type motor winding insulation burning/melting together/shorting windings, etc. due to shorts, high-temps, and/or high current. In a previous life, I have had electric motor windings dipped and baked with special insulating varnish at specialty motor shops. I have not (yet) removed/replaced my transmission fluid - or sampled it for color/smell.
    Any additional insights regarding the three subcodes mentioned above?
  16. dolj
    dolj Senior Member
    7,657
    3,872
    Wellington, New Zealand
    The B1421 you can pretty much ignore unless it throws outside in bright sunlight. You should see it set or unset in realtime as the light goes from dull to bright. From what I can gather it is not a trouble code as much as it is an on/off indicator for the photo sensor, unless as I said above it stays on in bright sunlight.
  17. Patrick Wong
    18,200
    6,474
    Unfortunately P0A7A 325 is somewhat ambiguous: "Generator inverter fail (GFIV) signal detection (over current by inverter assembly malfunction)"
    Here is the suspect list:
    Wire harness or connector
    HV transaxle assembly
    Hybrid vehicle generator
    HV control ECU
    w/ converter inverter assembly
    Since you have Mini VCI, you should follow the manual with respect to reading the freeze frame values associated with "Exclusive Info 4" and that will help you to pin down exactly what component has failed. Good luck.
  18. Montex
    Portland, OR
    I rechecked my trouble codes today:
    P0A7A/325 and P0A92/261 are set (current and historically.
    I'm using a Mini VCI scanner connected to a Win XP laptop.
    The Mini VCI tech software also indicates that the CAN bus is not communicating.
    My 2008 Gen II Prius 'readys', starts, runs, and idles. The MFD displays a charging path from ICE to HV battery OK. The A/C comes on and works OK.
    However, if I press the accelerator pedal, the ICE speed RPM increases, THEN the RED BANG TRIANGLE appears, sets the trouble codes above, and there is a) no more response from the accelerator pedal, and b) no charge path indication on the MFD (like there was before). Pressing the accelerator pedal does nothing after the trouble code sets. However, after shutting-down the car, re-readying, I do see MFD charge path from ICE to HV Battery again...then when I press the accelerator again, the ICE stops accelerating, and the charge path disappears.
    Any thoughts about this? Bad/loose connector(s), wiring harness? Thanks in advance...
  19. Patrick Wong
    18,200
    6,474
    Sounds like MG1 in the transaxle has failed.
  20. Montex
    Portland, OR
    @ Patrick: I'm hoping no, but... I need to get under the car and check the harness connectors too.
