Dice in prius 2007 ????
Discussion in 'Gen 2 Prius Audio and Electronics' started by shar1950, Aug 6, 2007.
  1. shar1950
    shar1950 Junior Member
    merritt, bc canada
    Is anyone out there using a Dice unit in a 2007 Prius with just plain stock cd/radio ? What are your dice switch setting for all 4 toggle switches ? I have my at up, down,up,up, and I have no control with steering wheel or radio mfd.
  2. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    What does it say on the screen? CD2/MP3?
    Do you have a satellite radio kit? Have you tried setting the switches to DOWN/DOWN UP/UP?
  3. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Vagabond @ Aug 6 2007, 01:29 PM) [snapback]491430[/snapback]</div>
    I just have stock cd/ radio without any thing else. I have tried all differant setting with no luck .
  4. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 12:48 PM) [snapback]491439[/snapback]</div>
    Right, but I need to know what the screen is saying and in what mode to start figuring out an answer.
  5. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Vagabond @ Aug 6 2007, 02:47 PM) [snapback]491483[/snapback]</div>
    The screen is displaying, cd changer, there are 1...to ...6 number blocks, the screen I have no control over at all. One time I pushed #6 block and title [ it showed dice v1.4]. Is one of the old problem firmware ?
  6. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 01:58 PM) [snapback]491494[/snapback]</div>
    So when you have the DIP switches UP/DOWN UP/UP it does not say mp3 in smaller letters next to the CD2?
  7. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Vagabond @ Aug 6 2007, 03:23 PM) [snapback]491503[/snapback]</div>
    with the switches up/down,up/up. There is a dc changer in the upper left corner and no where in the display is there a cd2 or mp3. Just to be sure the car config switch is up/down and i-pod config switch is up/up.
  8. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 02:40 PM) [snapback]491508[/snapback]</div>
    Ah. Press the CD button again til you go back to the iPod and see if the text appears then.
  9. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Vagabond @ Aug 6 2007, 03:43 PM) [snapback]491509[/snapback]</div>
    which cd button are you referring to ? I have no control from my mfd or the wheel. My stereo is just am/fm with single play cd,if that helps.
  10. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 03:09 PM) [snapback]491527[/snapback]</div>
    The CD button that you use to select the iPod/CD deck. The physical button.
  11. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Vagabond @ Aug 6 2007, 04:40 PM) [snapback]491544[/snapback]</div>
    The button that I use to select what is playing is on the steering wheel and it goes like this ....AM....FM1...FM2....CD.....CDCHANGER.......AM....FM1... and so on. Again have I received the latest updated unit with the new firmware or do I have a old unit ?
  12. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 03:50 PM) [snapback]491549[/snapback]</div>
    The button on the headunit itself.
    That's for an 04-05, but the CD button that's next to the AM/FM buttons.
  13. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Vagabond @ Aug 6 2007, 04:55 PM) [snapback]491552[/snapback]</div>
    Ok I see what you mean...... I just tried that and it just move between cd/player and cd/changer and I have it on cd/changer,still no text or any control from wheel or mfd. I have just sound,no control .
  14. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 06:15 PM) [snapback]491611[/snapback]</div>
    Then I guess the last question I have is what is the number on the bottom of the unit and where did you get it from?
  15. Sokolum
    Sokolum New Member
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 12:23 PM) [snapback]491426[/snapback]</div>
    I am also using the Dice unit in my 2007 Prius and I have problems with it too. It will be working fine, then I go to switch songs (after doing it several times already) and I lose the controls on the stereo and steering wheel. So annoying! The only way to get it going working again is to reset the unit: power down my stereo, turn off the car, unplug the cable from the Dice unit for about 30 seconds, plug it back in and then start everything up again. My IPod config switches are in the Dice Mode (both off or up).
    Does anyone else have this problem?
  16. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Sokolum @ Aug 6 2007, 07:50 PM) [snapback]491636[/snapback]</div>
    I'm at work now, so can't get to numbers on the unit but I purchased the unit through the priuschat shopin April through Danny. What do I need to do tomorrow and get this unit replaced ?
    Hello Sokdum....I did all that at one time and still didn't fix problem, I think we have firmware problem with the dice unit.
  17. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(shar1950 @ Aug 6 2007, 07:30 PM) [snapback]491655[/snapback]</div>
    Shoot me your contact and mailing info by PM please.
    <div class='quotetop'>QUOTE(Sokolum @ Aug 6 2007, 06:50 PM) [snapback]491636[/snapback]</div>
    You have all 4 up?
  18. Sokolum
    Sokolum New Member
    <div class='quotetop'>QUOTE(Vagabond @ Aug 6 2007, 09:49 PM) [snapback]491714[/snapback]</div>
    Yeah, I have all 4 up. Is my problem not normal?
  19. shar1950
    merritt, bc canada
    <div class='quotetop'>QUOTE(Sokolum @ Aug 6 2007, 10:53 PM) [snapback]491715[/snapback]</div>
    Hello Vagabond..... I just sent you the info Shar1950
  20. Vagabond
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Sokolum @ Aug 6 2007, 09:53 PM) [snapback]491715[/snapback]</div>
    Well no. You're actually using it in the wrong mode. 2006's and 2007's should use MP3 mode or SAT. Try unplugging the module from the car, and setting it to UP/DOWN UP/UP for Mp3 or DOWN/DOWN UP/UP for SAT. See which one you like better.
