DICE installed now dead battery.
Discussion in 'Gen 2 Prius Audio and Electronics' started by kenoarto, Mar 31, 2015.
  1. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    OK now I've really done it. Prius has been flawless till now. Installed a used DICE unit last week. Works nicely. Immediately after install, while I was testing two different USB adapters, I got the triangle of death (and all the blinking lights) for a few seconds, so I quickly turned car off/on, and that problem went away. Came out to locked car a week later (yesterday), battery was totally dead. Car started right up with jump. Wth?!? Could I have knocked an important wire loose while moving the block of electrical wires? Battery is 6 months old and was well charged.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    i saw here where someone else hooked up a dice and it drained their battery. you got it hooked to constant power or ign on power?
  3. kenoarto
    396
    Chicago, IL
    I plugged it into the back of the radio port (CD2) per directions from DICE/AudioVox. . Nothing else is attached for power.
