DICE (or other) for iPod with Package #6?
Discussion in 'Gen 2 Prius Audio and Electronics' started by imichaeldotorg, Apr 22, 2007.
  1. imichaeldotorg
    imichaeldotorg New Member
    Just got a 2007 with package 6 - it has a 6-CD changer already installed in the car. Am wondering if I want to use a DICE unit to connect my iPod, will I lose the 6 CD changer functionality? I keep hearing people talking about plugging the unit into the "CD Changer" port.
    Also, is DICE the best unit out there? Does it display track info on the screen?
  2. mike.s
    mike.s New Member
    25
    <div class='quotetop'>QUOTE(iMichael.org @ Apr 22 2007, 07:47 AM) [snapback]427709[/snapback]</div>
    Best for what's promised. Worst because it doesn't do what's promised.
  3. priusFTW
    priusFTW Gen III JBL non Nav
    434
    White Mtns New Hampshire
    <div class='quotetop'>QUOTE(mike.s @ Apr 22 2007, 05:02 PM) [snapback]427921[/snapback]</div>
    I tried dice and it did'nt work for me, probably due to a bad unit. They were very happy and quick to exchange it. By that time I decided to ditch it completely for the Vais Tech SLI and am very happy with it's performance.
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    The DICE iPod unit worked fine in my 2005 Prius. It displays track, artist, and album name on the MFD. You keep all your CD Changer functionality; the DICE is seen by the head unit as CD2.
    Which is the source of most problems: The head unit doesn't know what an iPod is, so the DICE unit has to pretend to be a weird CD changer with different "disks" mapped to different functions to control your iPod. Disk 1 is the current playlist, or if no playlist is selected, the entire contents of your iPod, sorted by artist name. To switch playlists, you switch to "Disk 2" and then each "track" is a playlist. Other "disks" have other functions. It works, but it's klugey and confusing.
    On my 2007, so far I've burned some MP3 CDs. The head unit does understand folders, so I can make a folder that corresponds to an iPod playlist and play that folder. The MFD shows song info, but you can't browse while moving... I play my iPod through the Aux input in the center console and choose a playlist on the iPod while stopped.
  5. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(iMichael.org @ Apr 22 2007, 04:47 AM) [snapback]427709[/snapback]</div>
    You'll keep your in dash changer. You'll see a 2nd CD changer with the DICE kit installed, that's how it talks to the car. You'll see artist and track info on-screen. The iPod charges while it's plugged in and the car is on, and you will be able to control the music from the headunit/steering wheel or iPod.
    <div class='quotetop'>QUOTE(mike.s @ Apr 22 2007, 02:02 PM) [snapback]427921[/snapback]</div>
