DICE problems
Discussion in 'Gen 2 Prius Audio and Electronics' started by Fab2004, Jan 11, 2007.
  1. Fab2004
    Fab2004 New Member
    I installed DICE last Saturday on my 04' Prius.
    When I first connected it to the MFD all worked fine, I got text, could change playlists, albums, the works!
    After putting the car back together, the MFD stopped working (not responsive to keys, not showing any info, etc.).
    I disconnected the DICE unit and reconnected it, and now it's working in "reduced functionality" (tried to disconnect and re-connect several times and didn't get any different result).
    What I mean is that in the 6cd changer, only the 1cd icon is enabled. I can listed the music from the iPod and change tracks, but I no longer see the music meta (artist, title) nor the time, the track number is not in sync, etc.
    Does anyone have any advice?
    Thanks
    Fabio
  2. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(Fabio @ Jan 11 2007, 02:33 PM) [snapback]374152[/snapback]</div>
    Wow, a '94 Prius!? Where'd you get that? :p
  3. ScottY
    ScottY New Member
    1,250
    Long Island, NY
  4. Fab2004
    Fab2004 New Member
    <div class='quotetop'>QUOTE(Marlin @ Jan 11 2007, 10:06 AM) [snapback]374173[/snapback]</div>
    ooops :rolleyes:
    <div class='quotetop'>QUOTE(ScottY @ Jan 11 2007, 11:23 AM) [snapback]374247[/snapback]</div>
    I did just that today, but only playing around with the dip switches fixed the problem:
    a. DICE mode -> iPod mode
    b. powercycle
    c. iPod-> dice mode
    d. power on
    now all works fine, but I placed the dice unit in a location more easily accessible because I feel I will need to do it again in the future.
  5. jdoakley
    jdoakley New Member
    <div class='quotetop'>QUOTE(Fabio @ Jan 13 2007, 05:35 PM) [snapback]375248[/snapback]</div>
    Do you think you could be more specific regarding your instructions? My dice worked fine, but then stopped displaying song titles (and could not be controlled from the steering wheel), and then, after changing the DIP switches (as suggested on this forum), stopped working completely. (I of course changed them back...)
    I have a 2005 with no CD changer, so now I can at least use my single CD again ;)
    Thanks,
    Jonathan.
  6. Fab2004
    Fab2004 New Member
    That's now happened a couple of times, so I've installed the DICE unit in a position where I can reach it easily.
    All I have to do is to unplug it from its connector and plug it back in (i.e. powercycle it).
    <div class='quotetop'>QUOTE(jdoakley @ Mar 22 2007, 08:52 PM) [snapback]410686[/snapback]</div>
  7. tvgaffer
    tvgaffer Junior Member
    I have a simmilar problem except the whole NAV,Climate,audio, and all steering wheel controls stop working sometimes not consistant at all and the screen reads external system not connected. OUCH!!!!!
    <div class='quotetop'>QUOTE(Fabio @ Jan 11 2007, 01:33 PM) [snapback]374152[/snapback]</div>
    <_<
  8. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(tvgaffer @ Mar 23 2007, 10:02 AM) [snapback]410945[/snapback]</div>
    Wait, what happens now? You have a DICE iPod or HD kit installed?
