Did an EGR clean out Plus Spark Plugs. Plugs look pretty rough.
Discussion in 'Gen 3 Prius Main Forum' started by chuckiechan, Jul 23, 2022.
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Attached is a photo of my plugs - 90k hot California miles of all kinds of weird seasonable blends.
    They are pretty beat up, comments welcome.
    59EA71B1-CFEA-4E5F-91B6-AA3B18AD8B10.jpeg A185B16C-2C84-4BC8-9185-D128DF2DF2D6.jpeg
    Lastly and most important the EGR cooler was completely clogged, barely passed water. I was about to give up and buy a new one and my pit crew suggested a pressure washer. Blew that baby clean in five - ten minutes.
    BTW, the pressure washer was a gasoline model, fyi.
    BTW, what actually happens when the EGR cooler is clogged tight?
    #1 chuckiechan, Jul 23, 2022
  2. nicosprius
    nicosprius New Member
    Nashville
    From my experience it can cause a nasty misfire it’s crazy how you can’t see through those things at all before a crazy clean job
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Hmm, 90k is kind of low to have a completely, or nearly clogged egr cooler. You must spend more time than average with the ice engine running.
    Our egr cooler on a 2011 at 124K was only about 80% plugged up with carbon and oily gunk. Spark plugs looked really good too.
    chuckiechan likes this.
  4. xliderider
    8,056
    3,223
    Honolulu, HI
    You should have installed an oil catch can between the PCV valve and the intake manifold as well.
    Did you also clean out the intake manifold and the small EGR passages under each intake opening?
    If your cooler was clogged, your intake egr passages will need attention as well.
  5. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    Yes I cleaned everything including the throttle body, EGR cooler, EGR valve, EGR pipes, manifold passages and everything else recommended in the various videos, plus a set of plugs.
    And speaking of plugs, at 90,000 miles a couple of the electrodes looked cooked. (See photos). The ground electrodes were white and the plug black. Don’t know what to think of that.
    But…
    It definitely runs better. MPG indicator hasn’t settled down yet.
    We don’t do much freeway driving in the Prius mostly large, fast boulevards.
  6. bisco
    51,155
    the clogging probably affects the plugs. normally, when most change them at 120k, they look very good still
  7. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Was that engine drinking a lot of oil? When the cooler is completely clogged, the computer should back off on ignition timing to minimize knocking. That would impair efficiency.
  8. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    It was using quit a bit of oil. I’ll know if something changes I check it often.
