Did I get ripped off?
Discussion in 'Gen 2 Prius Main Forum' started by brad34695, Aug 23, 2007.
  1. brad34695
    brad34695 New Member
    99
    Tampa Bay Florida
    I recently paid $70 for an oil change and rotation of tires on my '07. It was my first oil change, and I insisted the tech use Mobil I 5W-30. It seemed a bit high for me, but that was my first syntheic oil change, as my previous car was an old 90's clunker. I am due to have my oil changed again next week as I am about to hit 10,000 miles. I trust that mechanic I normally use but don't want to get ripped off, nor do I want to go to the dealership as I feel they are even worse crooks. I guess I don't need the tires rotated again until I hit 15,000 miles, which would reduce the bill closer to $50. Any advice??
    Brad
    Tampa Bay
  2. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    <div class='quotetop'>QUOTE(brad34695 @ Aug 23 2007, 09:38 PM) [snapback]501312[/snapback]</div>
    My dealer gave me coupon book so the first several oil changes are free. I did have the tires rotated at 5000 mi. It cost $22.00
  3. Godiva
    Godiva AmeriKan Citizen
    10,339
    I bring my own oil and only get charged labor. I only bring three and specify not to add any of their own, I'll top it off at home. That way I can be sure I won't be overfilled.
  4. moolman
    moolman Member
    142
    16
    <div class='quotetop'>QUOTE(brad34695 @ Aug 23 2007, 05:38 PM) [snapback]501312[/snapback]</div>
    No, you did not get ripped off since you asked for Mobil 1 Synthetic. Of course there are ways to cut you costs such as going to a place that gives you free tire rotations. BTW If you want to use synthetic, don't use Mobil 1, just do a search online for the base stock they use. They use a base that really isn't synthetic.
  5. brad34695
    99
    Tampa Bay Florida
    <div class='quotetop'>QUOTE(moolman @ Aug 23 2007, 09:57 PM) [snapback]501329[/snapback]</div>
    WOW! Thanks. I have heard read so many posts saying that Mobil I was the best to use. I want to use the best oil for MPG and general care of the ICE. Which oil do you recommend??
    Brad
  6. richard schumacher
    7,664
    1,043
    United States
    Anything with the right API rating will be fine, if you change it on schedule. I use Mobil 1 but it's overkill.
  7. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    markup on mobil1 is pretty high. i bet a good chunk of that money was for the oil.
  8. msirach
    msirach Member
    321
    Southern Illinois
    You were RIGHT to request Mobil 1. I use Amsoil which is expensive too. Pure synthetics are superior in lube qualities as well as life. I run the Amsoil with Amsoil filters for up to 36000 miles or 12 months. My Insight has 156000 miles and still does not use any oil between changes.
  9. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Check with your local Goodyear dealer to see if they offer this. I was told recently by a Goodyear dealer that all Goodyear dealers are supposed to offer free rotation on Goodyear tires.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    To buy Mobil1 here in the supermarket costs $50 for 5 litres. The dealership probably charges that for 3.5 litres of Mobil1.
  11. derkraut
    derkraut Member
    299
    28
    SAN
    I buy Mobile1 at my local auto parts store (Kragen's) for under $6 a quart. Tire rotation is free @ my goodyear tire dealers. You should NEVER have to pay $70 for the service you have described. OEM Toyota oil filters are less than $5 at the dealerships around here, or Fram filters are $3-4 @ auto parts stores.
    Were you ripped off? Yes, IMHO
  12. Devil's Advocate
    922
    Las Vegas, Nevada
    Amsoil is the best. Especially the 2000 brand all synthetic. I go 35,000 between oil changes. 17,500 between filter changes, i know odd huh? and am on my third oil change. one Amsoil oil change will run you about $65 for the oil and filter buy then you are done for a year!
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The reason to rotate tires is to even out the wear ... so the whole set last longer. If you pay $30 to rotate them on every oil change (5k miles), for the life of the set (50k miles), it will cost you $300.
    With at set of OEM tires $295 shipped from tire rack, it does not make sense to rotate every 5k miles. Tire rotation may not cost $30.
    To me, I wouldn't pay $75 (1/4 the cost of the new set) on the rotation for the life of the tires. From that I can say $15 per rotation every 10k miles is reasonable.
  14. Devil's Advocate
    922
    Las Vegas, Nevada
    On tire rotation, you should be able to do that yourself in about an hour. Plus, almost every tire place now has lifetime rotation if you buy tires from them. At least that's the deal I got at Tire America.
  15. Ehash
    Ehash New Member
    28
    <div class='quotetop'>QUOTE(JimboK @ Aug 24 2007, 07:31 AM) [snapback]501475[/snapback]</div>
    Would you trust a goodyear dealer to change your oil? I haven't reached my first oil change, and I'm almost scared to go anywhere but the dealer, in case they don't know how to work on the Prius. If advised to do so, I'd LOVE to go to the goodyear down the road from me and enjoy the free rotations along with the less expensive oil changes!
  16. patsparks
    10,664
    567
    Apart from the electric side of the prius which requires no maintainance there is nothing especially different about a Prius.
    An oil change is so simple no one could get it wrong.
    Screw out drain plug
    remove old filter
    screw on new filter
    replace plug
    add 3 litres of oil
    Start engine
    Check oil level and top up to full mark.
    change window sticker
    Tyre rotation
    Lift car on hoist
    Remove all wheels
    Move front wheels to rear
    Move rear wheels to front, swap sides
    Bolt on wheels
    Lower car to the ground
    Check wheel nuts with a torque wrench.
    Always get a fixed price before work starts on your car.
  17. AOV
    AOV New Member
    302
    Poughkeepsie, NY
    <div class='quotetop'>QUOTE(patsparks @ Aug 24 2007, 09:05 PM) [snapback]501832[/snapback]</div>
    Have a question on the tire rotation....
    Bought Goodyear TT's (great tires!) and its about that time for a tire rotation...
    Called the tire dealer and asked them if these particular tires would get back to front rotation or cross-over as you mentioned above. He said that they are "directional tires" and only get a back to front rotation. He said that usually 4x4 trucks, pick-up trucks have the cross-over rotation done.
    Any comment on that?
  18. Bob64
    1,540
    93
    Virginia
    look in the manual. If I recall correctly, it specified a back to front...
  19. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Typically the tires don't cross over during rotation; it's a simple front/back switch on each side.
    Those of us in the US add three quarts of oil, not litres, however the difference is only five percent (about 1.6 ounces).
  20. JimboK
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(Ehash @ Aug 24 2007, 08:40 PM) [snapback]501829[/snapback]</div>
    It depends on the dealer and their track record. If they've proven reliable in the past, I might consider it. Even then I would still caution them about overfilling, and maybe, as others here suggest, bring my own 3 quarts of (synthetic) oil.
    But it's a moot point for me. I do my own oil changes.
