Did I mess up my transmission?
Discussion in 'Gen 2 Prius Main Forum' started by kellykungfu, Jul 7, 2005.
  1. kellykungfu
    kellykungfu New Member
    Hi All,
    I was going down a slight hill and parked rather quickly. Must of been 3-4 miles per hour when I hit the Power button before I came to a full stop. The car stopped extremely fast and I was jerked hard.
    Did I mess up the transmission or engine? The car seemed normal after that.
    Also, I noticed before that happened, that when I let my foot off the gas pedal, on a level street, the car seemed to slow down too fast. The emergency brake was off (at least the light was not on). I also put it in neutral and it seem to coast a tad better. Not too sure if I'm just being too sensitve about it.
    Thanks,
    kelly
  2. silentak1
    silentak1 Since 2005
    893
    28
    LA
    You're fine. The tranny is built tough to withstand that kind of stress, but of course don't do it again.
  3. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Hey, Kelly.
    I can't speak for the transmission thing. I'm sure that soon enough someone with the tech specs will chime in.
    As for the rapid deceleration, what you are experiencing is the "drag" of the regenerative brakes. The wheels are turning the electric motor to generate electricity to recharge the battery. But don't confude this with .
    There are two ways to coast without this:
    1) a practice called "feathering" the accelerator pedal to create a state in which your MFD shows no arrows coming from the wheels, from the engine, from the battery, from wnywhere. You will notice that the car seems to accelerate. It's just that the drag has been removed.
    2) shift into Nuetral like you did. Some people do this on a regular basis since it's easier than feathering. Also, there are times when I just can't seem to get the "no arrows" state and [N] would do the trick.
  4. Tideland Prius
    16,164
    It's fine. I think >5mph, Park won't engage.
  5. KTPhil
    KTPhil Active Member
    1,379
    Powering off engages the parking pawl in the tranny (or more accurately, its equivalent in the HSD system). Doing this while moving risks breaking the mechanical park lock.
