Did I ruin my car by turing it on without hybrid battery installed?
Discussion in 'Gen 2 Prius Main Forum' started by kindleprius, Jul 2, 2022.
  1. kindleprius
    kindleprius Junior Member
    usa
    Hello All,
    I had the hybrid battery issues so I did the following:
    0. Drove my car to a shady spot, forgot I left my windows rolled down
    1. Disconnected the 12v battery
    2. Disconnected and removed the NiMH hybrid battery
    3. Realized that left windows
    4. Connected 12V briefly to roll up windows.
    5. Turned on the power button (no foot on the brake)
    6. Saw car lights turn on, and then everything go blank.
    7. No electrical system is not operable
    I just covered the windows with a tarp.
    Did I do anything irrecoverable? Did I damage anything?
    How do I close my windows until the hybrid battery is fixed?
    Thanks.
    2005 Prius.
  2. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Never tried starting a prius without the pack, but I suspect you'll be fine once the pack is back in and the error codes are cleared.
  3. kindleprius
    usa
    I hope you are right. I am getting very nervous about having wrecked the EUC or something.
    Every 12V system is dead after the initial power-on.
  4. PriusCamper
    12,064
    4,896
    Put your 12v on a charger while you get the work done... Also check the fuses. You want to eliminate those concerns before you get the pack back in.
  5. bisco
    51,155
    you can't turn it on with the safety plug out. either put the hybrid battery back in, or tape plastic over the windows
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    What does the HV safety plug or battery pack have to do with the 12V system "not working at all"?
    The car won't go to Ready, but you should be able to power the ignition on and roll the windows up, scan all the ecu's, etc - as long as the 12V battery still has power.
  7. mr_guy_mann
    3,966
    1,914
    NJ-USA
    What does the 12V battery read with a digital multimeter at the battery and at the underhood fuse box?
  8. kindleprius
    usa
    Hello All,
    I pulled out the 12V battery and put it on a trickle charger whilst waiting for two new cells to arrive.
    I am glad to report that reinstalling the HV and the aux battery does indeed poweron the car and I was able to close the windows.
