Did Prius do away with the the thermos.
Discussion in 'Gen 4 Prius Technical Discussion' started by padroo, Dec 30, 2017.
  1. padroo
    padroo Senior Member
    2,763
    2,250
    My old 2008 Gen 2 had the thermos to hold hot coolant for quicker warm up. Did they do away with it?
    I don't hear the Gen 4 making the sound.
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    There is no coolant heat storage tank on the fourth-generation Prius. I assume Toyota’s engineers decided the improved exhaust heat recirculation system (developed jointly with Sango Co., Ltd., and described in SAE Technical Paper 2016-01-0184) and the new active grille shutter system made it unnecessary.
    pilotgrrl and RCO like this.
  3. Fester
    Fester Active Member
    201
    198
    Ohio
    I think the thermos was dropped after the gen 2. My '08 did have one and I always knew the sound the thermos pump made for a few seconds following shutdown. Although lengthy, YouTube has some excellent videos by Weber Auto showing systems and changes from each generation of Prius and one I linked (on the active shutter thread) shows the gen 4 coolant system with the shutters and a detailed look at the exhaust system heat exchanger for faster warmup.
    Kramah313 and padroo like this.
  4. Mendel Leisk
    38,728
    No thermos on 3rd gen. I believe it was the gen that introduced coolant heating through the exhaust, too.
    Kramah313 and Raytheeagle like this.
  5. padroo
    2,763
    2,250
    I must have missed that episode that John Kelly does for Weber State in Utah. I will be looking for it today, thanks for the info.
    I found the YouTube video about the Gen 4 Prius cooling system, excellent video.
    #5 padroo, Dec 30, 2017
  6. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    One of my sisters called that sound "the dialtone".
  7. Tideland Prius
    16,155
    Yeah just the Gen 2 had the thermos.
    The exhaust heat recirculation system took care of the warm-up cycle.
