Did some lighting mods
Discussion in 'Prius c Accessories and Modifications' started by Baoser, Sep 26, 2013.
  1. Baoser
    Baoser New Member
    17
    Milpitas, California
    Sorry for bad pictures. but you get the idea.
    So first up we have a set of 35w 5k HIDs. Visibility has increased and great looking cutoff lines in the projectors.
    And also some interior lights.
    Rear wasn't quite as bright as I would have liked it...so here is a ghetto way of increasing light output just by a little bit.
    Everything was super easy to install, lowbeams took me maybe 8 minutes for both sides and the LED's maybe like 2 minutes... Definitely something that can be done cheaply and very effective.
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Do the LED lights still fade away? Or do they just shut right off?
  3. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    The LED's should fade off
  4. Baoser
    Baoser New Member
    17
    They do fade off, and it takes about 30 seconds or so.
  5. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    For my middle dome light, I installed a surface mounted multi led panel. I think It has 24 individual LEDs. Works well, fits fine and is nice and bright.
    My map lights are just cheapy regular t10 LEDs which are still brighter than stock.
    All of them fade out nicely.
    Baoser likes this.
  6. Baoser
    Baoser New Member
    17
    I don't have a middle dome light =(
  7. koipond
    koipond Member
    198
    39
    Where did you get your led headlamps? Just the bulbs or was it more complicated? I'd love to go LED with the headlights but don't want a project that will get complicated.
    P.s. just re-read and I see you did HID lamps... question answered... thanks!
    Baoser likes this.
  8. Baoser
    Baoser New Member
    17
  9. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    i would highly go against using led bulbs for replacement of high beam. it will not do anything!
