Did the Clicking surgery. Goi'n in.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ItZGr8t!, Mar 4, 2017.
  1. ItZGr8t!
    ItZGr8t! Active Member
    75
    284
    IE
    This should fix the good old brake clicking plus drain & refill for my CVT. CV Axle job was super easy now let's see for the ATF drain & refill. Will Update soon...
    Former Member 68813 likes this.
  2. JC91006
    16,827
    8,600
    Transaxle fluid has to be WS fluid, not the ATF stuff you have
    m.wynn likes this.
  3. ItZGr8t!
    75
    284
    IE
    HOLY CRAP!!! Thanks for pointing that out DAMN Dealer packed me the wrong fluid, i shall exchange it tomorrow. OMG Thanks so much man.
  4. Mendel Leisk
    41,873
    You need four quarts (or liters) of Toyota ATF WS. It's spec'd in Owner's Manual. I've attached an excerpt from Repair Manual below.
    That's pretty gutsy: doing the drive shafts. I wouldn't have the nerve.
    #4 Mendel Leisk, Mar 4, 2017
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Did the axle come out easy or a lot of prying?
  6. ItZGr8t!
    75
    284
    IE
    I guess buying from a dealer doesn't always mean that your getting the "right" fluid as they should know everything about your car :cautious:
    I was calling around for this kind a repair and the lowest quote i got was $515 with a "rebuilt" axle! i was like Seriously?
    I was expecting it to be hard but with the help of a puller it only took me 1.15hrs from raising the car, pulling out the axle to putting back the tire.
    #6 ItZGr8t!, Mar 4, 2017
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,725
    1,762
    Bay Area
    It looks pretty straight forward. Too bad my vehicle doesn't have any problems for me to film :cry:
    Raytheeagle likes this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    How many miles are you up to now on your 2012? I am about to click 150 k miles on the clock with our 2010.
    You around the Saturday the 25th? There is a meetup at @Rebound 's place in Fremont. If you're around, stop on by:).
    You sure you don't want to do any filmings "just because":whistle:?
    m.wynn likes this.
  9. NutzAboutBolts
    1,725
    1,762
    Bay Area
    I think my work Prius is at 134k miles. I've done all the maintenance already and now just driving it until the HV battery needs to be changed. Not sure what the 25th entails but i will have to see.
    And filming the Prius is fun, but just because won't be too fun lol I do want to film a brake job though, but it's costly :( and the Prius brakes are still thick lol...
  10. JC91006
    16,827
    8,600
    Volunteers?
    m.wynn and Raytheeagle like this.
  11. NutzAboutBolts
    1,725
    1,762
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  12. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    More than one Prius? My brakes at 150 k miles are still like brand new, otherwise I would offer mine up for the sake of filming ;).
    Any other jobs you have been Savin up to do films on?
    I'll keep you in mind when at ~ 200 k miles the egr system and intake manifold will come off for cleaning. That should be a good video topic(y).
    I just got a smart phone for 2016 Father's Day, so my technology skills are behind the curve a bit:sick:.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I cleaned out my EGR pipe around 100K and it as really clean, just some very light ash. I think the EGR and intake manifold stay clean until your rings start to go, and then the problem is your rings.
    Maybe we'll pull my intake on the 25th. That would be a good thing to do with other people around.
  14. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Sounds like a plan(y). You going to get some gaskets just in case?
    How many miles are you up to on your PIP?
  15. NutzAboutBolts
    1,725
    1,762
    Bay Area
    Maybe EGR and intake, but gonna have to see how difficult and I wonder if it'll be dirty or not, we will have see.
  16. ItZGr8t!
    75
    284
    IE
    SPOT THE DIFFERENCES . I need to check my service records regarding this comparison, it's way too dirty & less than 4 was drained. Exactly 4 quarts was put in.
    It's so quiet now when I step on the brakes that I could hear the passenger side very faint clicking :mad:, oh well I guess that would be my next project.
    m.wynn and Aaron Vitolins like this.
  17. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Sounds like @Rebound would be a willing participant in intake manifold removal and inspection.
    If you can swing the 25th, you'll have a new addition to your channel(y).
    m.wynn likes this.
  18. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Did you notice any scoring on the axles? Dealer that did mine at 30k noted some and I've had the clicking just learned to live with it. Brake fluid flush is my next project
  19. ItZGr8t!
    75
    284
    IE
    Didn't notice any scoring on mine, the axle itself looked like new when I wiped it down the boot was still intact but the problem is the internal parts.
  20. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Axle resonance rubber peace...you have reused from old axle?....one that is on the shaft.....otherwise you will have unpleasant noise at some speeds
