Did the head gasket change now im facing problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicosprius, Dec 12, 2022.
  1. nicosprius
    nicosprius New Member
    Nashville
    So I had my head gasket changed by my father and two friends they took their time on the job almost an entire month to be honest and made sure everything was leveled and nothing was bent. However now when I try to start the car it will go in ready mode and power up but the gas engine will try to start but shakes hard and cuts right off. My father thinks it’s not getting gas to the engine but I have no idea.. fuel pump is working we checked that.. any idea or suggestions would help I have no idea where to start at this point.
  2. nicosprius
    Nashville
    I can start the car and upload a video to show what exactly it is doing if that would help
    52,390
    any trouble lights?
  4. Mendel Leisk
    41,902
    What miles is it at? Were there shakes before the head gasket change, and if so for how long?
    Maybe damper (between engine and transaxle) is damaged? Or bent piston arm?
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,508
    6,595
    Texas Hill Country
    Did it run correctly after the head gasket job or are you still trying to get it to run right the first time after the work?
  6. Tombukt2
    Tombukt2 Senior Member
    13,416
    2,415
    Durham NC
    Sounds to me like when your head gasket was starting to go or going other things took some of the beating like the plate in between the engine and transmission that can lead to excessive strain on the small end of the connecting rod just my new flexing of that connecting rod in a open deck engine is a recipe for immediate disaster so you're saying when they did all this they looked at the back of the center girdle not the head not the oil pan but the center section it's three pieces for technically but we're not going there and you made sure that none of this center section is cracked right under the exhaust manifold across one two three and four you want to make sure that that whole girdle is intact I can send pictures of what it looks like broken out of the car while the engine is still basically assembled turned upside down so looking at it from the car you need to roll the car up on ramps or jack it up and slide from the radiator underneath the car till you can look at the back side of the engine facing the firewall your head will be the back of your head will be up against the firewall almost and you'll be looking at the back of the engine about midway up You're looking for literal cracks in the aluminum they will be noticeable with a flashlight seriously
  7. nicosprius
    Nashville
    I have no trouble lights. They checked for bent rods and cracks. The car would start and drive fine before taking it down to change the gasket. It had a shake too it and was losing coolant check the cylinders and could see coolant/water so we ch aged the head gasket I went a head and changed the water pump spark plugs and coils we changed ever gasket that the kit sent. Now the car literally will not start the gas engine it powers on comes right into ready mode but as soon as the engine tries to switch on it shakes hard and turns off.
  8. nicosprius
    Nashville
    this was the first time we tried to run it after the job
  9. bisco
    52,390
    did you use oem plugs and coils from a dealer?
  10. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    EGR valve stuck open? Leave EVAP hose disconnected?
    moto g power ?
  11. Mendel Leisk
    41,902
    Timing chain off a tooth? Or would that be total disaster?
    #11 Mendel Leisk, Dec 12, 2022
  12. Tombukt2
    13,416
    2,415
    Durham NC
    I'm thinking you should have some codes and some lights on It should be telling you that something's not firing that should be or vice versa. I when I did mine we had a bunch of nonsense going on on the head gasket change then the engine center girdle blew out from a bent rod and then upon changing the engine and transmission to a low mileage JDM spec setup we had a Christmas tree set of lights on the dash initially trying to start the car but that was all due to corrosion on battery terminals on the HV battery Not much else that wreaked havoc on the water pump and other things in the car trying to run to get the car running once the HV battery was replaced The car started up almost instantaneously with almost no undo hiccups
  13. Tombukt2
    13,416
    2,415
    Durham NC
    I'm not saying that you're in a similar boat here I was just saying that's what happened to us I hope this is not what's happening to you. But it's also very hard to detect bent rods and all this sort of thing when you just have the head off is really tricky I mean other than rotating the engine around and seeing where the pistons top out that's about all you've got and a slight bend will almost make the travel look correct and you won't see it A real trained person might but just the regular somebody probably not and I think that's where some of this gets folks in trouble it's difficult to see And then after you put the stuff all back together with that slight bend it's not long until the reciprocating mass takes that bent rod and makes it fail more than the center girdle breaks from the clanking of the center plate springs bottoming out and things like that happening.
  14. rjparker
    10,508
    6,595
    Texas Hill Country
    Generally bad shaking is caused by misfires. Contaminated plugs are the most common reason for misfires.
    We have seen lots of people miss-align the timing chain. We have seen sensors not connected and hoses missed. We have seen plugs fouled with oil and coolant that eventually burns off.
    Obviously you check your coils and plugs. I would discount the egr system and damaged damper plates.
    2010moneypit? likes this.
  15. rjparker
    10,508
    6,595
    Texas Hill Country
    Aftermarket plugs and coils can be defective. Hopefully oem parts were used. Sometimes switching to the old parts is diagnostic.
  16. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I would check timing chain marks as others have said.
