Did the Toyota dealership not change my oil and still charge me for it? (Pic included)
Discussion in 'Gen 3 Prius Main Forum' started by Sal43, Jan 3, 2020.
  1. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    In all my other cars I've ever had you can just open the hood to look at the new oil filter and then look at the color of the oil from the dipstick on a paper towel to confirm that the oil has been changed.
    I only drove the Prius 1,650 miles in 1 year from the last oil change and maybe that's why I can't tell the difference between the old and new oil.
    I put oil from before and after the oil change from the dipstick on a paper towel and you can't tell them apart.
    Do you think they didn't change my oil or was my old oil just as clear as new oil?
  2. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    If you only drive 1650 miles, the oil will not be dirty. Unless you are able to actually watch them,
    the only think you could do is to send the before and after oil in for a test.
    There should be some difference.
    I would bet they changed it. Unless you think they are a shady place.
  3. Leadfoot J. McCoalroller
    7,157
    6,711
    Pennsylvania
    2018 Prius c
    All your other cars got their oil dirty faster.
    I don't think they are cheating you.
    49,429
    those both look a little dirty, how many miles on your engine?
  5. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    61,670 miles.
  6. Mendel Leisk
    38,700
    With our 2010 I find oil on the dipstick looks very clean, right up to oil change time, which I'm doing at an admittedly very short 3000~4000 kms on average (once every 6 months). Still, if I collect a little bottle of the drained oil, it's black as ink.
    If you could siphon or drain a few oz's you could tell: near-new oil should still look amber, transparent. Loosening the drain bolt till you get a trickle is one way, but it's a bit nerve-wracking. I've done it on occasion, to remedy overfill.
    A syringe style siphon with hose down the dipstick tube would be easier.
  7. N H
    N H Junior Member
    32
    Syracuse, NY
    Once my dealership said they did a tire rotation and a tread check, but couldn't supply the paper or remember the numbers when they were done. They also find some new issue everytime I go in, so I am beginning to think my dealership is either sketchy or just reckless
  8. bisco
    49,429
    retchy? sketchless?
  9. Mendel Leisk
    38,700
    feckless?
  10. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Oil experts here say oil color doesn't necessarily reflect oil age or engine wear. Some claims here have been once fresh clear transparent engine oil is poured into the engine, chemical reactions take place and oil darkens quickly. Not all oil will darken quickly due to various formulation. Red line won't go dark coffee brown til 12,000 miles for me.
  11. Kenny94945
    Kenny94945 Active Member
    783
    399
    Sausalito
    2016 Prius v wagon
    Well, with only 1650 miles the old oil may not have changed color.
    I guess the question is do you trust the dealership?
    If they cheated you, and you can not prove it, some say synthetic oil can be okay to change every two years, so I don't think you have a problem as the oil still has a golden tint to it.
    Maybe the only way to know for sure is to send an oil sample to, for example, Blackstone Labs.
    I think the test cost is $30.
    Good luck.
  12. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Only way to know for sure is change it yourself.
    Or have a friend do it.
    I stopped going to my Toyota dealer after 5 loyal years. Yes I waited too long, but all is well.
    Luckily Prius only need the oil changed and tires rotated in that time. And a filter or two
    I now change my oil, rotate tires, etc.
    I have also done a trans drain. Brake check and lube and
    other various maintenance on both my Prius.
    Honestly, if I found out that the oil was never changed, or if all those multipoint inspections were never done,
    brakes were never looked at, tires were never rotated etc.
    I would not be one bit surprised.
    I will say tho, there may be some honest dealerships out there.
    Mine actually never tried to pull anything on me, but I now only go for state inspections.
  13. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    So of the 5 years of oil changes there, you only had the filter changed once or twice? Oh boy...
    kenoarto and dig4dirt like this.
  14. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Yep!
    I was referring bout them those there engine filters and cabin filters
  15. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    You want to type which kind of filter because the topic is oil change then I'll believe you meant 1 to 2 oil filter changes in 5 years :ROFLMAO:
  16. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    I can remember paying for a 500 mile service + valve adjustment for my motorcycle at a sketchy dealership. It was many hundreds of dollars. I bought some clear nail polish and rain a bead across the block, valve cover gasket and cover. I picked up the bike and the polish bead was broken. They could have done a shoddy job but at least someone pulled the cover and it gave me piece of mind.
    2012 Prius v wagon 3 likes this.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    What do you do but trust the dealership?
    Oil changes are pretty basic and rudimentary procedures. You would think a service center wouldn't put themselves at risk for charging for services they didn't do. If you have paperwork stating they did the oil change? I'd trust the work was done.
    Since less than 1,700, on your previous oil, probably not expected to see a big difference in color.
    Comparative paper towel test? Just going to feed angst.
    If you are going to drive less than 2000 miles between oil changes, I wouldn't subject myself to the worry by even comparing. All it's going to lead to is some dirty paper towels.
