Did this -'Easy P0420 test defeat'- work for you??/
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Sep 24, 2022.
  1. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
  2. Tombukt2
    Tombukt2 Senior Member
    13,803
    2,504
    Durham NC
    That looks like a cheap brass plumbing fitting. The fitting that I bought to do this with is heavy duty steel that also can rotate up and down and it contains a piece of catalytic converter brick in it I can see it in there that's what it's advertised I think I paid a whopping $12 for the thing. I have not installed it yet. Before I do I'm going to try a set of upper and lower O2 sensors first and then I have something similar to this video but a little better made right here in the drawer and we'll see if that works that did not work on an '02 Corolla with the AC Delco computer problem that they did make a flash for.
  3. ski.dive
    967
    247
    I just did this to mine and it cleared the PO42O =O2 sensor code
  4. Pioneerscot
    Pioneerscot Junior Member
    78
    Nevada
    Where did you get the part please ?
  5. ChapmanF
    18,954
    It might be better to change the thread title from 'P0420 fix' to 'P0420 test defeat' or something like that. It's not fixing anything, just preventing the car from noticing the converter's not doing what it's there for, and giving you the code.
    Sometimes people understand that and that's all they want to do. But we shouldn't be leading other people to thinking it's a 'fix'.
  6. Pioneerscot
    78
    Nevada
    It did seem like a few people are replacing the cat and still having the issue, resorting to this work around ? Im just preparing myself, had a jeep compass do that to me a couple years back, lots of time and money.
  7. ChapmanF
    18,954
    Yeah, if you replace the cat with an inadequate one, the code will be back as soon as the car tests the new one's adequacy.
    Pioneerscot likes this.
  8. Pioneerscot
    78
    Nevada
    Interesting, so the only ones up to snuff are Toyota provided ?
  9. ChapmanF
    18,954
    I don't think that's the case. But certainly there are cheap ones that aren't.
    The test the car does isn't looking for a Toyota hologram or anything. It just runs the engine lean for so many seconds to bank up some oxygen in the cat, and then rich for so many seconds to see how long the cat can still do its job. The ones that can't make the grade set the code.
  10. Pioneerscot
    78
    Nevada
    Interesting, is there a list of approved, or better yet, units that are successful in being used for replacement ?
  11. Tideland Prius
    16,668
    Updated title to "...P0420 test defeat..." instead of P0420 fix
    Mendel Leisk and Pioneerscot like this.
  12. Pioneerscot
    78
    Nevada
    Do you recall where your part was obtained ?
  13. Tombukt2
    13,803
    2,504
    Durham NC
    Yes if I'm not mistaken eBay and the person or people still sell it today I think I saw one the other day but I can't swear to it It's made out of stainless steel It's in the advertisement and it's like a flip joint that goes on the end of a grease gunjust larger . It has a nut on the section in the center that swivels so you can swivel it to any angle and then lock the nut and it stays put and then it has another nut where it mounts into the threaded boss on the pipe so again you can screw it in as far as you need back it to where you want run the lock ring up against the pipe and it stays put there and if I'm not mistaken it was $18 in 2021 or something Is sitting here right here on the shop desk I'm looking at it I ordered another one too but I don't know what happened to it It's got to be around here somewhere it's very similar just from another manufacturer both are Chinese and I don't think there's any legal ramifications for selling them as they are not creating any real modification to the car It's just an adapter if you will so I can't see where EPA or any other governing body would bother the manufacturer or their representatives for selling this product I can see where estate agency like an inspection station could say you need to remove it because the way they read the law.
  14. Pioneerscot
    78
    Nevada
    Thank you yes, I actually did find this extension unit. But in more research, I really need to see if my cat is damaged and if so is it due to excessive oil consumption. I did not realize before buying one of these cars that that was an issue. This forum is very enlightening and a smart man would have spent time here researching BEFORE making a purchase on an 08 with 222k on the clock. The deal on the car was good so I figured I could repair the minor stuff and still have a decent car.
    I have replace the traction battery with one from the dealer ( from Japan ) and a couple cosmetic pieces and gotten the car registered here in Reno, it passed smog after driving it for a couple hundred miles, although, in the first 35 miles after replacing both batteries, the P0420 code came up, I cleared the code and it stayed off long enough to get the smog test done. Now it’s back, and now it comes on right after being reset within 20 miles.
