Diesel "shortage" : Fact or Fiction??
Discussion in 'Fred's House of Pancakes' started by ETC(SS), Nov 3, 2022.
  1. bisco
    49,401
    there's so much negative hype in the media these days, i don't bother paying attention unless there is something i can do about it
  2. ETC(SS)
    6,545
    I was planning on ignoring it myself because....I don't buy diesel. ;)
  3. Trollbait
    11,517
    It's pretty much the same factors in effect as has lead to increased fuel prices in general; old refineries have been shut down, others are doing maintenance, world events, heating season starting, etc. The reserve stock pile volume is below average, but it is being replenished.
    Diesel is running about $2 more a gallon than regular gasoline here. I don't think the general efficiency advantage is going to make that up.
    It is going to hurt those using it for heating.
  4. ETC(SS)
    6,545
    Not trying to victim shame, but people using home heating oil REALLY need to switch.......
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    To what.....coal maybe ??
    IF heating oil prices have gone up in step with diesel fuel, then propane might be more competitive now.
    But switching to propane might involve an entire new furnace.
    AND....heating oil can be stored in an INSIDE tank and that should NEVER be done with propane.
  6. Trollbait
    11,517
    There are homes that still do use coal. Once worked with a guy whose house did so.
    With an inside tank, it doesn't take much to switch biodiesel; think it just needs a different nozzle to address viscosity differences. Though that doesn't necessarily address the fuel cost issue.
    Heat pumps are another choice, but the regions mostly using heating oil without natural gas as an option, seem to also have high electric rates.
  7. bisco
    49,401
    everything is going up here. i doubt switching fuels will help anyone.
    we have oil, propane, electricity. all are spiking, and so is ng. even cord wood has sky rocketed.
    one of the ng suppiers said they are worried about shortages if it is a cold winter
    2879390
    #8 bisco, Nov 3, 2022
  8. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    If biodiesel is available in our area, I would have changed to it long time ago. In a mean time, the heating oil prices is back up again. It is getting close to the record high $6/gal.
  9. jdenenberg
    jdenenberg EE Professor
    3,852
    1,844
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Luckily we prebought our heating oil (900 gallons) this Summer while the price was a bit lower.
    JeffD
    Salamander_King likes this.
  10. Salamander_King
    10,970
    8,853
    New England
    The lowest spot rate price we got in our state was ~$4.50/gal at the beginning of September. Our oil company had prebuy price ~10% higher than the spot rate, so even if it was pre-bought around the lowest point, it would have been ~$4.95/gal, and I had to make a 100% payment upfront. I filled our tank about a month later at a $4.888/gal spot rate. With your purchase amount, it would be over $4,000 payment. Luckily, with our usage, I only need to buy another full tank sometime in the middle of winter before the end of the heating season. We use ~400 gals for 6 mo heating season and another 200 gals in 6 mo non-heating season for hot water.
    #11 Salamander_King, Nov 3, 2022
  11. sam spade 2
    7,035
    2,788
    2017 Prius c
    Many/most of the areas using heating oil are too far north for a heat pump to be a viable choice for heat.
    And the electric infrastructure might not be capable of supporting a mass change to resistive electric heat.
    Making a change likely is not as easy as one might think.
  12. ETC(SS)
    6,545
    If you have to ask, then you should contact a qualified HVAC professional.
    My experience with and knowledge of using HHO for home heat is limited to my childhood years in my beloved home state of Indiana, and while I'm sure that yuge efficiency leaps have been made with these systems in the decades since then, I'm thinking that either propane or natgas "might" be more efficient.
    Even today.
    We had a buried HHO tank pumped out and backfilled with sand when we upgraded our home to a gas-fired boiler in the 70's.
    I asked then why they went through the trouble of burying the tank, and it was explained to me that only an idiot would have 500 gallons of oil in their basement.
    Again, I was a kid and somewhat gullible back then.
    I believed them.
    I still bear a faint scar on my left wrist that looks embarrassingly like a knife wound from back-hauling that old oil-fired system, and I remember the smell from fuel.
    I also remember that back in those long ago times, we were forced to actually import oil in this country and so the prices fluctuated somewhat.
    I remember also being cold in the winter because we had to adjust our thermostats to conserve heating oil.
    Somehow all of that just went away after we switched over to a gas boiler system.
    Again....
    I'm sure things have changed a LOT since the 70's, and none of this really applies to me much because I don't live in the frozen wastelands above I-20.
    I have a heat pump in my city house that I plan to augment with ventless propane heaters as a backup.
    The advantage of having the ugly tank in the back yard will be as a backup fuel supply for home generation in a post storm environment that I can fill at will and (like HHO) lends itself to long term storage, and my generator is a dual-fuel unit.
    MY mileage.
    Yours might vary. ;)
  13. hill
    8,163
    Propane .... It ain't cheap any more either ..... it's gone up in lockstep like other fossil fuels - based off our multiple 100Lb tanks that we use for emergency purposes.
    #14 hill, Nov 4, 2022
  14. Rmay635703
    Rmay635703 Senior Member
    2,593
    1,610
    Somewhere in Wisconsin
    2013 Chevy Volt
    Thank the moronic oil investors.
    Diesel “days on hand” isn’t much different than it has been for the last 1.5 years.
    The difference yet again is that nobody wants to repair or build new refineries so anytime one is down or under repair the entire world ends.
    Plenty of oil compared to Trump 2020 when we had 124 active rigs and now have over 700 but we have been loosing refineries for 25 years with a large number shuttering permanently during p45
  15. sam spade 2
    7,035
    2,788
    2017 Prius c
    There is still some risk with ventless gas heaters.
    Before you buy anything, I suggest that you check the building codes in your area.
  16. jdenenberg
    3,852
    1,844
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My prebuy price was $4.59 per gal (including a small charge for downside protection which seems unlikely to be useful this season) near the end of the Summer. Today the spot price is just below $6 per gal
    JeffD
  17. ETC(SS)
    6,545
    There's risk with using a toaster with your pop tarts, and I live on free soil.
    But...yeah. Good point.
    I have redundant CO protection, and my intent to use ventless is for aux/additional heating only.
  18. fuzzy1
    10,166
    Cold climate air-source heat pumps can now cover the vast majority of the heating season, much farther north than skeptics will give them credit for. Just be sure to keep some backup heat source for the really cold days, sub-zero to under -15F, depending on how much heat pump capacity one wishes to pay for.
    Ground-source heat pumps can go even farther north.
    Are any places where electricity is primarily non-fossil sourced, having electric price spikes? I haven't heard anything here.
  19. sam spade 2
    7,035
    2,788
    2017 Prius c
    Spoken like a true anarchist. :(
    You are NOT free to do things that have a high likelihood of having an adverse impact on others.......no matter how much you wish that was the case.
