Diesel sound?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by datdaddy, Apr 6, 2010.
  1. datdaddy
    datdaddy Junior Member
    17
    Netherlands
    When I'm just toodling along, say 30 kph or so and then press lightly on the accelerator while the gasoline engine is running, just light enough not to cause it to shift to a lower gear, the engine sounds like a diesel, like it's knocking/pinging or something. Has anyone else experienced this? It will also do it in other gears, but only at the point before the added acceleration causes a geardown. If I really put the pedal down, it does not do this. Any ideas? Should I take 'er in?
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Doesn't sound right to me. You're not running it on lpg or cheap petrol by any chance?
  3. datdaddy
    17
    Netherlands
    No -- I live in Netherlands and I buy fuel from a military base -- supplied though by local Dutch jobbers.
  4. datdaddy
    17
    Netherlands
    Oh, the fuel is rated Euro 95 for octane purposes (European index).
  5. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I would get it checked by the dealers, especially as it's a new car. Better to get the car checked incase it turns into a more expensive problem.
  6. datdaddy
    17
    Netherlands
    Gawd!!!! but thanks!
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    First, the Prius never shifts, so it isn't an issue of which gear you are in. There are no shiftable gears in a Prius.
    The Atkinson Cycle engine in the Prius uses a fairly high compression ratio for a regular fuel gas engine. To get efficiency, the Prius pushes the mixture and timing to the limit. This results in the engine sometimes sounding a bit like a diesel. It's completely normal.
    Tom
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    I respect what you say but sometimes it can sound like a diesel? You sure? Apart from 10 seconds when it did that cold start problem when stood for a few days mine has always run sweet and super smooth and quiet for a 4 pot engine. It has never sounded like a diesel ever and I work mine hard.
    I use the European standard premium unleaded 95 octane (87? US octane) not super 98 actane.
    I know I'd take mine straight to the dealers if it ran like a diesel and get them check for any error codes etc.
  9. qbee42
    18,058
    3,079
    Northern Michigan
    By sounding like a diesel, I mean that rattly sound that diesels make; the one that sounds like a few loose screws in an empty tin. Certainly the Prius doesn't sound like a big tractor diesel or something from an earth mover. On occasion it will do a little more rattling than what you might expect from a normal gasoline engine. It shouldn't do it all of the time, and it shouldn't be terribly loud, but once in a while under the right loading is normal.
    The lack of engine compartment sound insulation probably adds to the effect.
    Tom
  10. mmichaell
    mmichaell Member
    241
    chicago
    I have never heard any rattling sound ever on my 2010 Prius. Currently have 3,500 miles. Run standard 87 Octane gas.
  11. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    It could be the infamous dash rattle mistaken as engine noise.
  12. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I would try running a full tank of higher octane gasoline. The Prius has a very high compression ratio. Gasoline formulations vary state-by-state in the USA; I have no idea how they may vary in Europe.
    Can't hurt much to try.
  13. KenzoTH
    KenzoTH Member
    70
    38
    Rhode Island
  14. fuzzy1
    10,602
    Compression ratio is 8-something. That 13.0 ratio is exhaust expansion, not intake compression.
  15. datdaddy
    17
    Netherlands
    OK - good news here, and something to watch out for should you ever experience this problem. Took the car in to the dealer. Drove him around, explaining the whole thing. He heard it. Went back to the rack. Opened the hood. He said "I think I found it!"
    Turns out that when they did the update to the software for the brakes, they didn't quite get the hood prop rod back into place. So it was laying on top of the engine, vibrating every time I accelerated.
    Duh.
    But happy.
    m2
  16. datdaddy
    17
    Netherlands
    I'm sure that could've been funnier, but I'm too tired to think about it now.
  17. mcorbin
    mcorbin New Member
    Maryland
    Thanks so much for your posts, you just saved us hours and hours of hassle. We had exactly the same problem after the dealer did exactly the same software job and made exactly the same error of not putting in the hood prop (what's up with that?). I just went out and checked under the hood, and lo and behold there was one end of the prop lying on top of the engine. Test drove, and purrs like a cat.
    By the way in case anyone else is wondering about whether they have the problem, I thought the sound also sounded like detonation or "pinging," though it was a bit deeper than normal pinging.
    Love the forum,
    :rockon:
    Marcus Corbin
  18. datdaddy
    17
    Netherlands
    hahaha -- hard to believe there was another with the same thing!
  19. Tande
    Tande Active Member
    550
    337
    Mich.
    Yep...Same here...
  20. datdaddy
    17
    Netherlands
    Read the previous posts for the solution that we found.
