Difference between headlight assembly with HID and w/o HID (halogen)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by google2007, Feb 8, 2010.
  1. google2007
    google2007 New Member
    Hi yall!
    Recently, my 2008 prius was hit in a parking lot by a truck.
    So, I am thinking about replacing the broken headlight assembly by myself.
    But, I am not sure that there is any difference between one with HID and one without HID.
    Should I buy one that is clearly marked with HID, Or can I just buy
    one for the regular halogen lamp assembly and then use some parts from my broken assembly (Mine is with HID).
    Any advices would greatly be appreciated.
    Thanks
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    I think you should try to get the one that is clearly HID. They are different and there may be differences that are not readily apparent, but would prevent you from just transferring parts over from your broken assembly.
  3. Tideland Prius
    16,195
    HID. You need it for your high beams (a shutter activates that) which is not present in the halogen headlight assembly (they use a dual-filament bulb)
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    They're very different. In addition to the high-beam shutter, the HID housing has a bay for the high-voltage ballast on the bottom and an auto-leveling motor.
  5. lvthehun
    lvthehun New Member
    Las Vegas
    Anyone know where to buy it? Online not available at all.
    Maybe a part number?
    Thanks
