Difference in regen by pressing down on cc knob vs brakes?
Discussion in 'Gen 3 Prius Main Forum' started by hayden55, Feb 2, 2018.
  1. hayden55
    hayden55 Member
    115
    48
    I dont know if anybody else has noticed but if you have cc on above 25 mph and hold the cc stalk down it basically functions as a pretty dang strong elec brake. Is there a difference in regen efficiency on this versus the brake pedal? I noticed it would stop at a specific range in the band but still stopped at a strong rate. Thoughts, fellow Hypermilers? The reason I ask is because the old Prius guys and other hybrid enthusiast would wire in a circuit to mess with the resistance on the pedal to basically increase the strength of the regen without hardly touching the pedal and they reported a difference in mpg
  2. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    I noticed that too. I've been meaning to test some things out with torque to see if the brake pads get used, but it does seem that it brakes more than I could using the full regen capability (which is rather limited in the cold weather we have now). If that's just my mind playing tricks because I'm not actively braking, I don't know.
  3. qdllc
    qdllc Senior Member
    1,370
    399
    All I know is that when the CC is engaged, the system uses the max regen braking if needed. Pads do not engage. I’m not sure how that compares to pressing the brake gently. I think the system can tap more regen capacity while running the CC than you could with the brake pedal. I also know that if it can’t maintain set speed with regen braking, it will employ engine braking. If your battery hits max charge, it goes entirely to compresson braking.
  4. fuzzy1
    10,167
    I am not aware that CC can do so. The main potential advantage would be that CC doesn't blend in the friction pads along with the regen. And doesn't waste any energy on brake lights :).
    For reasons of better / faster / easier control, and less opportunity for operator confusion, I nearly always stick to the brake pedal regen. My foot can respond to sudden situational changes reflexively and nearly instantly, where my fingers on the CC controls can easily flub things.
    CC regen is reserved for moderate downhills were constant speed is acceptable. No slowing required, it only needs to prevent gravitational speed-up.
  5. hayden55
    hayden55 Member
    115
    48
    My typically way of driviing is called DWB or "driving without brakes" so I typically do a lot more p n g and regen as much as possible, and when I have to use the brakes it better be for a good reason. On my Honda that was the biggest increase to my mileage I saw right behind p n g, So I figured if I could get more efficiency out of the hybrid system I could go even further.
  6. bisco
    49,448
    a scan gauge will show it, i think,
  7. hayden55
    hayden55 Member
    115
    48
    Which setting?
  8. bisco
    49,448
    i don't have one, but folks here mention watching regen and caliper pressure on it.
  9. hayden55
    hayden55 Member
    115
    48
    Must be some sort of custom x gauge they setup. Im just a noob and use the std settings on mine.
  10. fuzzy1
    10,167
    Somewhere around here is a link to a Google spreadsheet with a huge list of codes for Prius-specific gauges for all this.
    Somewhere ...
    HERE:
    See also this long thread:
    https://priuschat.com/threads/scangaugeii-work-on-2010.64406
    #10 fuzzy1, Feb 6, 2018
    hayden55 and SFO like this.
