Difference in tires /mpg
Discussion in 'Prime Fuel Economy & EV Range' started by dnutbrown, Jul 28, 2023.
  1. dnutbrown
    dnutbrown New Member
    I had a 2017 Prius that i was averaging around 4.2 l/100 (56 us mpg) when on the factory tires -ecopias.
    I was rear ended and it was totaled , so I ended up replacing with a 2017 prime.
    When I got the car a few weeks ago it had almost new Uniroyal tiger paw a/s tires on it.
    I had to do a long trip right after getting it of 2500km and could not get lower that around 5 /100km (47 us mpg)
    All of this is running highway around 117 kph or 72 mph' and it felt down on power especially on inclines.
    I checked the 12 volt battery after one morning and it was 12.1 volts so swapped in a new one but it made no change in mpg. Air filter was clean.
    I took off the Uniroyal tires and put on a set of Bridgestone ecopia 422 plus tires and right away my mileage is up to 4.1/4.2 l/100km or 56 us mpg.
    These mileage numbers are calculated from fill ups and subtracting the km driven on electric per tank so are very close to accurate .
    My electric range also went from 37/40 to 45/47 km on average. You can feel the difference in how it drives as it feels like it handles inclines better and the rpms are lower on the same inclines.
    I do on average 340 km every day with a full charge in the morning and one before heading home so it is a huge difference in fuel used plus the 10km driven on electric.
    I would suggest to anyone to avoid the tigerpaws
    Dale
    bisco and FuelMiser like this.
  2. FuelMiser
    FuelMiser Senior Member
    1,302
    889
    Monument, CO
    With our first Prius, at one point I elected to cheap out on tires and mileage went down noticeably. Over the life of the tires, I calculated that I lost money on the deal by paying more for the extra gas than better tires would have cost in the beginning. Lesson learned.
    49,519
    not enough people are aware of the serious consequences of wheels and tires
