Different tires - front and back?
Discussion in 'Prius v Main Forum' started by CathySD, Dec 20, 2019.
  1. CathySD
    CathySD New Member
    2014 Prius v wagon
    Hi all, I have a 2014 Prius V five with 17" tires. I've been dealing with an ongoing tire saga and long story short - due to an incompetent alignment shop and having finally gotten my alignment fixed elsewhere - I have ended up with 2 good tires in the back and 2 bald tires in the front.
    I have been buying tires from Costco, but the back tire (Bridgestone Turanza Serenity Plus) is not in stock and for some reason they can't order it. This means that I will end up with 2 different types of tires. Is this going to be a problem? And if not, does anyone know the closest match to the Turanza?
    Thanks in advance,
    Cathy
  2. Offline
    Offline Active Member
    639
    231
    Lenexa, Kansas
    How much tread do the "good" tires have? Are they worth keeping? It's best to have four matching tires.
  3. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    We have had 2 pairs of tires of the same size but from different manufacturers on the front and rear of our Gen 2 Touring Prius and have not noticed any issues. While I agree that it is ideal that all 4 tires on your car are identical, when you stop to think about it, that is not likely to be the case for very long, even if you replace all tires at the same time. The front tires will always wear more quickly than the rear tires, due to the increased friction on them from steering and braking, regenerative or otherwise, so they are soon mismatched with the rear tires, at least to some extent.
    Hopefully one of the members can give you some information about which tire would be the closest match to the Turanza, but I would not stress about getting less than a perfect match.
  4. mikefocke
    3,701
    1,649
    Sanford, NC
    Same axle, same tires. OK Not optimum but as Dave said, never is for long.
    davecook89t likes this.
  5. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    Is the Serenity Plus in your size still in production? TireRack.com shows a Serenity <something else> for your car.
    #5 NewHybridOwner, Dec 21, 2019
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  7. mikefocke
    3,701
    1,649
    Sanford, NC
    Years ago, Pirelli made a pair of tires specifically for a Porsche and the tread designs and even tire widths were designed to be different front and back. There was a Porsche set of tests of any set of tires that Porsche would deliver on a new Porsche and the design would get an N rating from Porsche only after any needed design and construction changes to the tire and them finally passing the tests (and they were comprehensive tests). So with all that background on a specific car designed with asymmetric tire sizes to run to 120MPH on the autobahn and mid-engined and all that we know it is possible to even have different tread pattern on the car as long as they are on the same axle.
    Now also we know that it was a common practice on RWD cars to put snows only on the back. So different tread designs front to back.
    Still try and pick a tire with a similar tread design. You are trying to keep the tire characteristics as close as you can so the anti-lock braking system does not get totally confused. When you need that to work, you really really need it to work.
    Tires are my contact patch with the earth. It is an area I never tried to save on.
  8. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Not that big a deal as long as you have good tread. I've done it on my prius.....
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    But it is not necessary.....as long as you keep the matching pairs on the same "axle".
    I think that anyone in this situation should ask a tire shop or 6 and get the new tires that gets the most "votes".
    P.S. I get mine from Sam's Club and they usually are very helpful.
    Did Costco really NOT make a recomendation ?
    But the basic answer is: NO, unless they are wildly different, it should NOT be a problem.
  10. CathySD
    CathySD New Member
    2014 Prius v wagon
    Thanks all for your input! It's a relief to know that it wouldn't be a problem to have different 2 different tire models. I went back to Costco yesterday ready to see what they can offer and this time I spoke to a different person who was actually able to order the same type of tire from Bridgestone. The whole experience left me scratching my head, but I'm happy to have it resolved. Thanks again!
  11. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    With your set-up, you would not be doing tire rotation. Keep the good tires on rear, when the front wears out , bring the rear set to the front and buy tow new tires and put them on the rear. I was in a similar situation with my Gen3 with unmatched tires in front and rear. I had OEM EP20 and Ecopia 422 Plus. I would think any touring tires (which Turanza is) of the same speed and load rating would be fine. Only thing is that with this scheme, you do lose the opportunity to buy tires on sale for most of great sales on tires requires a set of four new tires. Also, since you will not be doing tire rotation, you will void any tire tread warranty, although those warranties are most often not worth claiming. As such, I ended up with purchasing a set of four new tires eventually, and leaving two newish tires I took off from Gen3 in my garage.
    #11 Salamander_King, Dec 23, 2019
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    The front tires are ALREADY worn out (described as bald)......and with mis-matching sets, there is no reason that they can't still be rotated front to back and they should be. Directional tires are done that way all the time.
  13. Salamander_King
    10,975
    8,868
    New England
    Sure, if the "2 good tires in the back" are almost new. OP did not say how much treads are left on those "2 good tires in the back".
  14. sam spade 2
    7,035
    2,788
    2017 Prius c
    OK, sorry I worded that poorly.
    I should have said "There is no reason that the tires can not be rotated front to back.........when all 4 tires are in good shape.
    It seems as though you are suggesting that she keep driving on her "bald" tires.......and that is NOT good advice no matter which position they are mounted on.
  15. fuzzy1
    10,170
    That is why the maintenance list calls for frequent tire rotations -- to keep the mismatch from getting large.
    That old practice of snows only on the back of RWD cars, predated ABS and stability / skid controls that could be confused. And it wasn't a particularly good idea even back then, due to poor steering from the front non-snow tires.
    JoneK and davecook89t like this.
  16. Salamander_King
    10,975
    8,868
    New England
    I would never suggest to keep driving with "bald" tires. My assumption was that OP's rear tires are still good, but substantially less tread than new. What I am suggesting is that when she is ready to replace those "bald" front two tires, bring the still good, but less than full tread rear tires to the front, and put the new tires on the rear. With this scheme, it is impossible to keep the even wears on front and rear sets of tires since already less tread front tires are going to lose the tread even faster than the brand new rear tires. The tire rotation is recommended for even wears on all four tires, but you just can't achieve that with this setup, unless you put the brand new tires on the front and keep driving until they are matched to the tires on the rear.
    This may bring up a hot topic on "When changing only two tires, which axle they should go". I advise new and better tires with more tread should stay on rear for safety reasons, but some people may argue differently.
    BTW, I found out that tire rotation is mostly US thing, and many European countries do not even suggest tire rotation. I for one did not rotate my tire on my Gen3 with miss matched tires until I eventually replaced all four tires with a new set.
    #16 Salamander_King, Dec 23, 2019
  17. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    Tire Rack, looks like you can still get these tires:
    Tire Rack - Search Results for Bridgestone Turanza Serenity Plus
    Not sure why Costco can't order. Show the this link and ask again perhaps.
    I'd agree with post above … as long as the matched tire are on the same axle …. you could do this.
    But...personally I prefer all 4 tires to be matched make and model.
    Good luck in your decision.
  18. sam spade 2
    7,035
    2,788
    2017 Prius c
    What is a "bold" tire ? She said BALD. I repeated BALD. As in, no tread left.
    There should be no "when ready".
    The time is NOW.
  19. Salamander_King
    10,975
    8,868
    New England
    My bad.:( Typo. Corrected "Bald". Yeah, NOW is the time to buy new tires, I agree. But if she is buying only two tires, then new tires should go to the rear, as suggested by most. But still, some may disagree.
  20. sam spade 2
    7,035
    2,788
    2017 Prius c
    I don't do that......but also do not disagree that it is the best strategy for most drivers.
