Digital clock not working
Discussion in 'Gen 2 Prius Main Forum' started by Eric Haycook, Dec 10, 2018.
  1. Eric Haycook
    Eric Haycook New Member
    Syracuse New York
    Hello all, I have a 2007 prius and my Digital clock that is on my Dashboard stopped working. It no longer turns on. Everything else in the car seems to be working fine.
    Any help would be appreciated!
  2. PriusCamper
    PriusCamper Senior Member
    11,119
    4,529
    Pacific Northwest, USA
    Find a pick-a-part type wrecking yard and practice popping-out the clock... Then pop out your own clock and make sure it's plugged in all the way. If it's not buy the clock you popped out at the wrecking yard and plug it in and see if the problem is fixed.
  3. Eric Haycook
    Syracuse New York
    Thank your for your response. Is it unlikely that it’s just a fuse?
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Doubtful it’s just a fuse. Check your owners manual but in 2006 the clock fuse also ran the Audio system and the MFD. if those were also out you would know.
  5. PriusCamper
    11,119
    4,529
    There would be other stuff on the dash that would be out than just the clock if it was a fuse...
