Dim / Autolight Problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brandon Pitts, May 15, 2022.
  1. Brandon Pitts
    Brandon Pitts New Member
    Acworth, GA
    I keep reading about head light problems, but I don't see any exactly like the problem I have.
    When I turn the lights to the on position, they work fine, both lows and highs.
    When I turn the lights to the auto position, the DRL work fine, but the lows and highs do not come one. I replaced all the fuses and relays. Any ideas what the problem could be.
    I'm hoping maybe someone knows something before I go through the hassle of replacing the stalk switch.
    2014 Prius, Three
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    900
    502
    Cow-lee-fornia
    2023 Prius
    There's also a button on the dash by your left knee that controls auto-high beams to come on and off. The sensor to turn the headlights on and off sits in the middle of the dash under the windshield.
    Something odd that I noticed was that when I replaced the 12v battery, its operation was smoother and quicker, at least I was under that impression. So try a reset by disconnecting and reconnecting the battery?
  3. BiomedO1
    BiomedO1 Senior Member
    1,459
    790
    SacTown, Ca
    Check your battery 12vdc voltage directly or at the jump point. It should be at least 12VDC; your systems will operate down to 11.5VDC - but some people notice odd sensor behavior.
    Make sure your sensor is clear; no dash mats or sun shades obstructing your rain/daylight sensor.
    If you do a systems reset; you must disconnect the battery for at least 10 minutes. Make sure the windows are down and doors unlocked; so if you mess something up - you'll be able to get into it; also have your stereo head unit access code handy. Do not just disconnect and reconnect the battery; the internal power supply capacitors needs to discharge for a full reset to take place. When or if I do a full reset; I usually take the opportunity to clean off the battery top, check electrolyte levels (if accessible), clean contact points and install anti-corrosion pads.
  4. ChapmanF
    15,557
    Would a Three have come with auto lights in 2014? I had to mod them into my 2010 IV. Did you, or a previous owner, maybe, mod them into yours?
    Seeing that your stalk switch makes different things happen in all the positions, I think your stalk switch works, and the hassle of replacing it would be misplaced. Seems more like it is doing its job in the AUTO position, that is, it is telling the body ECU "auto headlights please", and possibly the light sensor is making the ECU think it isn't dark outside, so the ECU chooses DRLs rather than headlights.
    Does anything change if you throw a sock over the light sensor on the dash?
    In addition to the headlights outside the car, you should (depending on your dash dimmer setting) be able to notice the instrument illumination switch to dim, when the light sensor thinks it is night out. Also, if you have nav, the map normally switches to its light-on-dark "night mode" at the same time.
    If the sensor input doesn't seem to be behaving, getting access to Techstream could be useful, so you'd be able to view the actual sensed light level being reported to the body ECU, and the stalk switch inputs. That can streamline your troubleshooting by a lot, compared to poking at things and guessing.
  5. Brandon Pitts
    Acworth, GA
    I have not modded it. It looks like a factory install to me. I am not sure about the three. It could be a four. I ran the VIN and it came back as three or four.
    When I cover the sensor, nothing changes. The DRL will come on, the dash lights dim, the little interior LED that shines on the dash comes on, and if I pull back on the stalk switch the brights come on and go off again once I release the switch.
  6. Brandon Pitts
    Acworth, GA
    Spent time examining the car and reading specs. I figured out the 2014 Prius Two does not have auto lights. They have a feature that dims the dash lights when driving in dim conditions like a tunnel. So problem solved. Nothing to fix because everything is working like it is supposed to work.
  7. ChapmanF
    15,557
    When I read the first sentence and then the second sentence, I end up not being sure I understood. The things in the second sentence, when do they happen?
