Dim Brake Light - Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Luv2travel, May 4, 2014.
  1. Luv2travel
    Luv2travel Junior Member
    NYC
    Hello! My passenger side tail light is much dimmer than driver side on my 2012 Prius v. Any thoughts on why this is and what to do about it?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to maintenance and troubleshooting from technical.
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    LED or incandescent? If LED, may be a warranty issue.
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    If incandescent, probably a bad connection. Try swapping the two bulbs side to side and see if the problem a) moves (then bad bulb) or b) stays on the same side (bad connection) or c) fixes itself (you managed to redo the connection when moving them).
  5. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    The combo (tail and brake) 2-element bulbs can also cause weird issues when one element breaks and shorts to the other. On a v-2 I'd expect those are not LED. You can't rule out the bulb without replacing it. (or swapping)
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    They also can cause odd problems if the ground wire is loose or corroded.
    As mentioned, first remove the bulb and inspect the socket.
    The bulb might just be loose in the socket.
