Dim Headlights
Discussion in 'Generation 1 Prius Discussion' started by DaveGoodrich, Nov 3, 2014.
  1. DaveGoodrich
    DaveGoodrich Member
    141
    67
    My (2001) headlights are always the dimmest of any car around me on the freeway. Is this a common issue with Prii? Yes, my lenses are clouded, but even when I clean them up, they are still dimmer (and yellower) than the cars around me.
    Is this a possible indication of a problem with the electrical system?
    Any recommendations for headlight bulbs I could try that might make them brighter. I can't remember what bulbs are in there now, but I think they are just stock replacements.
    Thanks,
  2. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    A good place to start would be to have the 12V battery and it's connections checked; also the charging voltage when in RUN mode.
  3. DaveGoodrich
    DaveGoodrich Member
    141
    67
    12v battery is near new. Battery voltage is 12.88 volts with car off (fresh from commute home), and 13.8 volts when running. No other electrical issues.
    49,415
    it might be a common problem for 13 year old pri.:cool:
  5. LEVE
    LEVE Member
    191
    97
    On the Willapa
    When you clean the headlights, can you tell if the inside of the lens is fogged?
  6. Easy Rider 2
    1,584
    257
    Ocala, FL
    Next would be to check the voltage at one of the lights.
    Battery voltage is only part of the story; if there is a loose or corroded connection somewhere along the way, the voltage at the lights might be down.
    Bad grounds are often the most elusive.
    Then, hopefully someone who knows what bulbs that model uses will chime in with replacement recommendations.
    #6 Easy Rider 2, Nov 4, 2014
