Dip-stick heater test -- no go
Discussion in 'Gen 2 Prius Technical Discussion' started by bwilson4web, Jan 19, 2007.
  1. bwilson4web
    16,352
    The dip-stick oil heaters are a solid rod and can't make the 'bend' in the dip-stick tube:
    FYI.
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(bwilson4web @ Jan 19 2007, 11:29 AM) [snapback]377726[/snapback]</div>
    So, you couldn't get your rod in the hole? :) I almost had the same problem with the block heater. But seriously, is there a reason for picking this over the block heater, or do you have both?
  3. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Oil tends to stick and form a glop at the end of the oil dip stick heater. Not recommended!
  4. rudiger
    rudiger Active Member
    696
    45
    Cincinnati, OH
    Those dip-stick oil heaters have been around for decades. You'd think that by now, someone would have been able to come up with a version that is able to accomodate the bends in the dip-stick tube.
  5. bwilson4web
    16,352
    <div class='quotetop'>QUOTE(Beryl Octet @ Jan 19 2007, 10:55 AM) [snapback]377734[/snapback]</div>
    It was an experiment and the dip-stick heater was sent for testing. I've been a little busy with some other tasks so this was my first attempt. I'll send it back since I don't feel like trying to modify the part.
    I have a block heater but not yet installed. I've been working on a thermistor hack and need a 'cold' engine to test. But I'm rapidly coming to a close on the thermistor hack testing. More about this sometime in the future.
  6. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(bwilson4web @ Jan 19 2007, 01:15 PM) [snapback]377794[/snapback]</div>
    Thanks, want to hear more about your thermistor hack. I've installed the block heater, figure I'm getting mabye 2MPG better overall during cold weather given my commute.
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    forget the thermistor hack as your wasting your time. Get another oil pan for the PSD and get a tube machined up and tig weld it into the pan and put another block heater in the PSD unit and get it warm. Block heater in the ICE left on for 3 1/2 hours at an OAT of 5C get's the ICE to 27-30C.
    Leave it on over night and it get's the ICE to 42C maybe a bit higher. Put one in the PSD as it has the same mass and the same fluid capacity as the ICE and get it up to the high 30's low 40's Celcius. That will significatly improve your mileage by reducing the fluid viscosity drag on the drive unit. IMHO
  8. bwilson4web
    16,352
    Hi Frank,
    <div class='quotetop'>QUOTE(Frank Hudon @ Jan 19 2007, 01:29 PM) [snapback]377851[/snapback]</div>
    In the above, we agree but the thermistor hack has other uses. For example, in cold, windy weather, less than 0C and more than 15 mph, even with the radiator block, I've seen enough cooling to force ICE operation. Also, the thermistor hack works when the car has been parked without AC power (aka., the office parking lot.)
    For my PSD, I bought a second PSD pan and have 'glued' the JC Whitney flat heater and installed a thermistor inside the pan. I've got some machining and tapping of the drain plug to fashion a low-profile sample-plug in the drain-plug. Once I finish the plug and pan, I'll post photos before and after installing.
    The block heater, pan heater and thermistor hack will provide optimum performance. But in six weeks, N. Alabama will return to our moderate temperatures and my cold weather experiments will be replaced by others. <grins>
  9. Frank Hudon
    4,147
    if your down around freezing I doubt that it's the ICE temp that's forcing the ICE to run, I get the same thing and if you look at your Battery temps you'll see that they are probably in the 2-7C range and it's the battery temps that are forcing the ICE to run to build heat to warm the battery. Just bump your MiniScanner to read battery temps and you'll notice that when they get to about 12C your ICE "problem" is gone.
  10. bwilson4web
    16,352
    Test results from thermistor hack:
    In all cases, ICE autostop worked as soon as the indicated ICE coolant temperature reached 70C. However, the 35 mph trigger speed and the stop for 6-10 seconds must occur to transition from S3 to S4 state. The savings is nearly 3.5 extra minutes in hybrid-electric mode versus having the ICE run, even if in idle.
  11. Frank Hudon
    4,147
    I was doing some timing on my first start of the morning but it came to a halt with a bicyclist hit by a car. I spent several minutes there so I'll try again tomorrow. In the afternoon I have a two mile run to a traffic light at 90KMH and if it's backed up no amount of ev will help. I normally shut it off or take the alternate route which is 7 miles to the first traffic light. I'll do some timing to see if the addition of the circuit will save me much.
  12. bwilson4web
    16,352
    Hi Frank,
    <div class='quotetop'>QUOTE(Frank Hudon @ Jan 19 2007, 04:25 PM) [snapback]377990[/snapback]</div>
    It is hard to get the battery down that low in North Alabama. This morning, the weather channel reported 0C but the miniscanner saw only 5C on the battery and 3C on the ICE coolant. I'll really need a day that never goes above 0C to cold-soak the car and battery.
    Do you have any metrics on how long it takes to bring the battery temperature up?
  13. Frank Hudon
    4,147
    Bob were into a warm spell again and today I clocked about 20 seconds where I could have forced the "ev" with a temp sender hack. First stop today I showed 72C on the miniscanner. I have some short climbs when leaving the house and then a flat run in traffic that should be going 30 mph but travels at 45 mph. Then I start an undulating climb of about 1000" in 47 blocks, the undulations is where I get HV battery heating with the draw down and recharge and by then I have warm air circulating thru the battery compartment and the temp by then is in the 12-16C degree range. Even after a weekend sitting the distance to that temp is pretty consistant. I'm currently doing 46MPG US on my commute, how does that compare to your milage?
  14. bwilson4web
    16,352
    Hi Frank,
    <div class='quotetop'>QUOTE(Frank Hudon @ Jan 25 2007, 10:05 PM) [snapback]380943[/snapback]</div>
    I've been concentrating on the implementation and getting some initial metrics. I'm not ready to report how effective it is because it will take me a little longer to get to that point. But as a quick hack, I picked up my GreenHybrid.com data for this chart but I don't have a good way to separate my 'learning curve' versus 'thermistor hack.' Still, the trends and ad hoc data look promising:
    One thing I'm starting to notice is I'm picking up on effects I hadn't noticed before. This evening, I first observed the "battery powered" mode in the first minute with a substantial, 45 A load as my car accelerated to 35 mph. I'm beginning to see the wisdom of Ken's initial 2 minute warm-up.
    I've also started to investigate these Stage 4 effects:
    1. 35 mph enabled EV - in stage 4, reaching 35 mph is required before backing off the throttle allows EV.
    2. 10 second stop - operationg of this trigger is not yet as predictable as I want.
    So far, it appears that to reach Stage 5, I have to pass through the 10 second stop. But it isn't clear if the 35 mph trigger needs to be reached first or if there are some other prerequisites . . . the experiment continues.
  15. Frank Hudon
    4,147
    yes the battery "boost" on first startup is significant. What I try and do is to give it a bit of quick acceleration to road speed and if no tailgaters I back off before the speed limit until I see less than 20 amps draw. I'm starting to think that the boost is on till the computer senses that the HC absorber cat is open to full flow and not recircing the exhaust gas thru the absorber. That signal I can only assume comes from the downstream O2 sensor or so it seems to me. I've tried watching the voltage but it's hard to decipher what is the point of the "boost cut off" but it seems to me to be about the time the HC absorber open. One day I'll tie in a vacuum gauge to the valve and watch the vacuum switch, and O2 voltage and the "boost".
  16. bwilson4web
    16,352
    <div class='quotetop'>QUOTE(Frank Hudon @ Jan 26 2007, 12:31 AM) [snapback]380981[/snapback]</div>
    Ok, this makes sense. If the HC valve is closed, it would be important to limit the gas flow. The cold-mode, EV would limit how much gas tries to force itself through the exhaust system.
    I don't have an NHW20 model but EV mode when cold may make sense to limit the amount of 'cold' operation and inefficient combustion.
  17. bwilson4web
    16,352
    I ran an extended test with the temperature hack on Monday evening and achieved a 5 minute, 45 second, 'stealth' run at the end. When I took out the hack, the ICE coolant was at 47C:
  18. c4
    c4 Active Member
    607
    51
    Bob-
    I assume that you're spoofing the coolant temp sensor reading when you're talking "thermistor hack"?? I've been doing this for more than a year now on my Classic.. I started with a manual 25K 15-turn pot in parallel across the coolant temp sensor leads, and manual monitoring with my Miniscanner, but now I've got a little PIC microcontroller and a bunch of programmable digital potentiometer chips (in parallel to minimize the wiper resistance) that automatically optimizes the temp reading for me.. In warm weather, it will ramp the temperature reading up to 70C rapidly, if the car has been run recently, it will move to 70C almost immediately, and in really cold weather (ie below 0C), it delays operation for a bit and allows the engine to warm up a bit to avoid MIL and codes.... Subject to the aforementioned conditions, the algorithm is rather simple- if the temperature is below 70C, it adjusts the potentiometer value so that the temperature reading to 72C (which I picked rather arbitrarily); once it rises above 72C, the potentiometer switches out of circuit and it goes into "monitoring mode", where it watches the temperature reading and switches in again at 70C and maintains the temperature reading at 72C until the engine warms up again and the cycle repeats..
    With the temperature sensor spoofing in place, where I used to have nothing better than 9L/100km bars for the first 5 minutes (in most cases it was pegged at the top), but with the mod in place, I'm seldom ever worse than about 7.5L/100km, and on most days, get much better; even now in the winter, on most days, I'm still better than 9L/100km on the first 5 minutes.. The savings are actually even more apparent in the winter when combined with radiator blocking because you get engine stop on all but the very coldest days, and stealth under virtually all conditions..
  19. bwilson4web
    16,352
    <div class='quotetop'>QUOTE(c4 @ Jan 30 2007, 09:23 AM) [snapback]382776[/snapback]</div>
    Excellent!!
    I first heard of adjusting the thermistor back in November when Clive Burk in the UK asked about the thermistor leads. I offered directions to the engine ECU and connector behind the glove compartment. Clive started using fixed resistors then the Prius_Technical_Stuff community quickly identified a forward biased, diode-resistor as a better solution. This preserves the high temperature readings as the diode takes the resistor out at low thermistor voltages. Cor worked up a two-transistor circuit and I took the MSP430-F2013 ($20 TI development kit) approach:
    http://hiwaay.net/~bzwilson/prius/pri_temp.html
    I'm reasonably happy with the results and plan to publish the source code listings. This was my first PWM project and the lessons learned will help with my next project. BTW, the folks in the YahooGroup, Prius_Technical_Stuff, would probably like to hear about your work too.
    I'm not volunteering but it looks like this could be a nice 'product' for an MSRP of $100. Maybe we can interest Coastal Electronics in the hack.
  20. c4
    c4 Active Member
    607
    51
    I ended up using a digital potentiometer because I started out with a manual 15-turn pot. when experimenting; I had considered various approaches such as switching out the temp sensor completely and spoofing the voltage with either a DAC or some sort of switched capacitor PWM, but it always came down to complexity and ease of programming, especially as I've got all the stuff necessary for PIC microcontroller development, and these chips have built in I2C for communicating with the digital pots and ADCs for monitoring the sensor voltage.. Using a parallel connection also appealed because the default state of the pots is max. resistance, so if anything zapped, the actual temp sensor reading dominates and the vehicle functions normally. I never thought about the diode/resistor combo, but that's my fault for being so digital oriented..
    The only technical hitch came in because most of these digital pots are meant to be in the gain stage of op amps and they have fairly significant "wiper resistance" such that just a few mA of current will result in a pretty large voltage drop.. It ended up not being a problem because the parts I got from Analog Devices (free samples even) were dual and quad devices that I could wire and control in parallel to minimize the wiper resistance.. The only variables then were the number of steps available in the pot and the max. resistance.. I'd have to double check, but I believe I ended up using a quad part with 200K max resistance and 1024 steps (ends up being 50K with 1024 steps when wired all in parallel).. Again, the free samples available from Analog Devices and a few other companies meant that I had a variety of components to experiment with at zero cost to me..
    In terms of construction, the only real problem was that most of the parts came only in surface mount varieties- I ordered the largest packages I could (eg, the SOT type, which could still be manually soldered to, and which Digikey sells "adapter boards" for), but a number of the parts only came in the new tiny packages with the microscopic lead pitches- and these ones I convinced our PCB guy at work to add a few "break out adapters" on the scrap corners of some of the stuff he was working on (these are the "frames" of the PCB that are snapped off after everything is complete, typically we lay out test lines here to ensure that the etching is of the correct width but these portions are basically scrap) and mounted the chips using the hot-air reflow equipment at work..
    I did a lot of experimenting to figure out how to optimize the insertion of the modifying resistance and how to vary it.. As you probably know from your own experimenting, the Prius programmers thought they'd be clever and do all sorts of consistency checks so inserting the resistance too early can result in MILs and codes, which wouldn't be nearly so bad if they didn't require you to switch off the vehicle and restart to get out of the "limp home mode".. I ended up writing code for all sorts of initial conditions based on thermistor readings- if the coolant is > 40C, the engine is still hot from a recent operation and it's virtually always safe to ramp up to 70C immediately; in between 25C and 40C, I wait 20 seconds, ramp up to 50C to get rid of the low temp light (it also seems to have some positive effects on available engine power), and then slowly ramp up to 70C. It's lower temperatures that cause some consternation because this is the situation where you have to watch how quickly you begin spoofing the readings.. If you're unlucky, you get an MIL right away; if you're really unlucky, the MIL doesn't come on until a bit later when you're already moving- I found one set of start up conditions that I thought was perfect- the car would consistently allow engine stop within 2 minutes startup, but the problem was that if you had to stop again before the engine had really had chance to warm up, the minute you hit the accelerator to go, it would pop the MIL and start moving ahead really slowly on battery only, which is rather unsafe.. I never managed to tweak this setting to fix this, so unfortunately, in most cases you have to delay the insertion of the pot and slow the ramp rates to gradually get the reading up..
    There seems to be some sort of interaction between the hybrid system and the climate control system as well- obviously if you use the A/C or turn the heat way up, the engine will start, but I've discovered that you can fiddle with the climate control to force the engine to stop as well.. I can use the A/C and Max A/C buttons as an "engine stop" command on my car- as long as the temperature knob is set to something reasonable, and the fan isn't going at max, if I turn on the A/C and the Max A/C button, and then immediately switch the A/C off, if the outside temperature is warm, the engine will stop immediately; if it's colder, it may take a couple of A/C on/off cycles to get the message across..
    I think the next project will be to figure out exactly what the climate control and hybrid control interactions are and potentially spoof these..
