Dip stick metric
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gliderman, Feb 1, 2016.
  1. gliderman
    gliderman Active Member
    751
    223
    Has anyone determined the amount of oil between the oil full dot and the oil low dot on the dip stick?
  2. Mendel Leisk
    38,720
    1.6 US quarts? Think it's in the manual somewhere.
    Yeah, page 427:
    #2 Mendel Leisk, Feb 1, 2016
    mmmodem and Dino33ca like this.
  3. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    that's A LOT/
    I wouldn't want to drive around with pretty much one third of the oil missing//
  4. Mendel Leisk
    38,720
    Just put another mark on it, one quart down, lol.
  5. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Toyota very likely tested to be sure you're still safe at or above the low mark. Let it drop any lower, though, and you're risking major damage.
  6. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Never mind...
  7. bisco
    49,481
    all you need is a thin film.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Thanks! I was roughly a quarter lower than I had filled it for my 90k change, so I guess the engine (I said engine instead of ICE :) ) burned roughly 0.4 quarts over 10k miles. Not bad. This means I can lose 1.6 quarts before I have to top up and if the loss is linear, I'll be there at 360k miles. That would be just fine by me.
  9. Mendel Leisk
    38,720
    .4 qt over 10,000 miles is very minor.
    CR94 likes this.
