Dips in charge / discharge current limits --> ICE on?
Discussion in 'Prime Main Forum (2017-2022)' started by lllars, Mar 26, 2019.
  1. lllars
    lllars Junior Member
    32
    Southern Vermont
    2018 Prius Prime
    We just got our prime a couple weeks ago. On a typical morning I drive my daughter to school (5 miles, downhill the whole way), then return home. I've been trying to make the whole trip without the ICE turning on, but have only managed it once so far.
    EV mode on. Speed < 84mph. Defrost off. No cruise control. Usually in "normal" mode, not "eco". Outside temps around 20F. Car is not garaged. Sometimes heat is on (but only if temp gauge reads > 14F). Generally car is fully charged (scheduled departure, lvl 1 charger). I do have pre-conditioning selected, but it doesn't seem to actually work.
    The trip starts with ~1mi down a steep-ish dirt road going about 20mph. Some regen is happening here. Stop sign at the bottom of the road. Then turn onto a paved road and going about 55 mph, still downhill but less steep. Car is consuming power at this point (not regenerating). Stop (car turned off) at school for a few minutes, then uphill all the way home.
    Typically I notice the engine turning on right as I accelerate away from the stop sign at the bottom of the dirt road. This is on the way to school (downhill). It's possible that the engine turns on a little bit before I get to the bottom of the dirt road, but that I'm not noticing it until I pull away from the stop. Only in the past couple days have I been putting the energy monitor screen up and also I learned about the green car icon being just an outline when the ICE is on.
    I can usually make the trip home from school without the ICE coming on.
    The one successful trip was actually in the afternoon, so at ~40F instead of 20.
    This morning I made sure the car was only ~75% charged, thinking the problem might be too much regen on a full battery. That seemed to work, I made it all the way to school. But, then the ICE kicked in halfway home.
    I just got the hybridassistant app yesterday, so I had that running this morning (but I wasn't watching it at all). Looking at the report, I'm seeing dips in the charge and discharge current limits, and it seems like exceeding those may be what kicks on the ICE. Is that true? And can anyone explain what causes these dips?
    I'm attaching the CCL/DCL plots from the hybrid assistant report. The plot with the dip in the red line is the downhill trip (ICE did not come on). The plot with the blue line dip is the return home, you can see that the engine is on from ~8:21:45 to 8:24:00 (where the green hybrid battery power is about 0). Let me know if more plots would be helpful.
    52,025
    when the ice kicked on half way home, how many miles of ev did you have left?
    you may be over thinking, over analyzing this. prime is not a pure ev, and there are many reasons built into the software to start the engine.
  3. lllars
    32
    Southern Vermont
    2018 Prius Prime
    Not sure how many miles it would have said. I had the % indicator showing instead and remember it being about 20% just before the engine kicked on. Was thinking at the time it should be just enough to make it home.
  4. schja01
    schja01 Senior Member
    1,836
    1,222
    Chicagoland
    2024 Prius
    Limited AWD-e
    The 20F is a killer.
    Also with a fully charged battery on a downhill departure where is the regen going to go?
    It spins (air compressor mode) to add resistance in the above case.
    "Just Drive It"
    FuelMiser likes this.
  5. lllars
    32
    Southern Vermont
    2018 Prius Prime
    Right, I get that. That's why this morning I didn't charge it all the way.
    No thanks. That's not my style. I like to know all the details of how things work :)
  6. bamike
    bamike Junior Member
    59
    32
    DC
    2018 Prius Prime
    Put it in EV mode, not EV auto and make sure it is in Eco mode. Also turn off the climate control. I have found that I can run with the ice off for 25 miles easily as long as all accessories plus climate control are off and it is in eco mode. However, I have not tested it below freezing.
  7. lllars
    32
    Southern Vermont
    2018 Prius Prime
    It is not in EV auto.
    Does Eco actually make a difference in terms of the ICE coming on? I thought it was just accelerator pedal responsiveness. I usually drive in "Normal".
  8. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    I thought ICE came on at 80 MPH or above. You said under 84 MPH. That could be your answer. Slow down, Lead Foot.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    You're misreading what he said/meant...
    Rob43
  10. bisco
    52,025
    when the ice kicked on half way home, how many ev miles did you have left?
  11. lllars
    32
    Southern Vermont
    2018 Prius Prime
    Not sure, as I had the battery % indicator up instead, which showed ~20% battery left. It should have been enough to make it home, albeit without much to spare.
    You can see that the graph shows 28% SOC (state of charge) at the point when the engine kicks on. I'm not sure yet exactly how SOC translates to the battery % shown on the MID, though. I have seen an 81% SOC reading when the car says it is fully charged.
    Yeah, I'm hitting about 65mph max. ICE comes on above 84 mph per the manual.
    #11 lllars, Mar 26, 2019
  12. bisco
    52,025
    if that's the case, then it is showing you the actual state of charge, which toyota limits at the top and the bottom.
    so you likely were out of ev miles.
    that would point to the downhill run starting the engine, and not starting it when you start out with 75%.
    the trick then will be to keep increasing the charge incrementally, until you get to the point where the engine doesn't start on the downhill, but you have enough ev left to make it home.
  13. lllars
    32
    Southern Vermont
    2018 Prius Prime
    I see what you're saying, but I don't think that entirely explains it. I agree SOC is probably > 0% when EV range runs out, but in this case I know there was significant EV range left when the ICE kicked in. I'm fairly certain it was reading around 20% on the MID (4-5 miles). You can see in the graph where the engine turns back off a couple minutes before I get home and it uses up more battery. SOC at the end of the trip was 24%, and I'd bet even then there was still a couple miles of EV range left (though I did not check).
    I really think it has to do with the dip in discharge current limit. Anyone understand what factors determine that limit or what might have caused the dip?
  14. bisco
    52,025
