Directional Flasher????Too Quiet
Discussion in 'Gen 3 Prius Accessories and Modifications' started by artieb, May 8, 2011.
  1. artieb
    artieb Junior Member
    70
    medford ma.
    2024 Prius
    Limited AWD-e
    Where is it? want add a small beeper buzzer thingy, put one on my M/C so I don't drive w/ signal on, easy to do w/ Prius, no sound from flasher to speak off .Radio shack has lots of things to put in but not sure where to tie into signal circuit, ideas ?? maybe different flasher w/ louder click???
  2. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I have noticed this also and left it on longer than I intended because I could not hear the ticking.
    49,433
    i think it's toyota. my wife is forever reminding me on our, pri, camry's and corolla's for the last ten years.
  4. luchinis
    luchinis Junior Member
    46
    Michigan
    like we need another beep sound in a prius!:D
  5. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Ample applications of Dynamat, no stereo, and silk-smooth roads... all are necessary prerequisites to the turn signal weeps not being drowned-out by the ambient din....
  6. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Can't please everyone..........geesssssss
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    If you've driven newer Fords lately, they use this 2001 Space Odyssey-ish electronic tone instead of the common clicking noise.
    That being said, the other day I noticed I was leaving the blinkers on. For whatever reason there was either more ambient noise, or the sound was more quiet than usual. Turns out I am more reliant on the noise to remind myself to turn the blinkers off. It was very annoying.
    I wouldn't mind it being louder.
  8. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    If you still have your eyes, just learn to be more aware of your surroundings.
  9. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Yes, I have always wanted a car that did not make that awful click-click sound every time the turn signal flashed. I love the quietness of the Prius turn signal. As 32kcolors says, you can be aware of the blinking signal on the dash, wish is plenty for me.
  10. artieb
    70
    medford ma.
    2024 Prius
    Limited AWD-e
    lots of replies but can any on answer my question please thanx
  11. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    There doesn't seem to be a customization setting for the directional flasher volume, only for the buzzer signals.
  12. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Think economics... supply and demand. e.g., on the demand side, have you considered:
    – An Ear Trumpet?
    – Ear Wax Remover?
    Of course you could just eliminate the entire problem with arm-out-the-window, hand signals. I'll leave it to you to venture over to youtube for your driving hand signal lessons--some are quite entertaining.
  13. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    That's weak. How about something that matches the hybrid technology, a cochlear implant? :p
  14. bisco
    49,433
    same problem with the one low fuel beep.
  15. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    Ha! Ear trumpets and ear wax removers go along with stuffing foam tubing insulation into the grille, the arcane shift lever, etc.!
    I actually thought about cochlear implants, but the Rush Limabaugh association scared me away.
    Also, I believe the 1930s Citroen had timers on their [ame=http://en.wikipedia.org/wiki/Trafficators]Trafficators[/ame]
  16. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    then you should buy a 2005 Bucik Lasabre, the directional on it was loud enough you could hear it outside the car.
  17. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    The blinking green arrow in front of you isn't clue enough?
  18. CivicSky
    CivicSky Member
    163
    71
    San Deigo
    I used to hate the clicker on my Civic! So I only flashed mine seconds before getting my green arrow for left turn. Back to the topic, you can certainly amplify it using a bigger buzzer below the "Start" button.
  19. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Per the Toyota repair manual, to get to the flasher, you start by removing the upper instrument panel assembly.:eek:
  20. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    OMG! That's borders on criminal! And I would assume it's covered by neither the standard nor the extended warranty :eek:
