Dirt in engine oil
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kamrul, Dec 12, 2024.
  1. kamrul
    kamrul Junior Member
    99
    17
    Bangladesh
    My 2013 has nearly 135K Kilometers (~84K miles) on it. I have been using Caltex Havoline engine oil for the past two occasions and this one has been in my car for around 6 months and driven nearly 5K Kilometers.
    So, I just took out the dipstick this morning to check the engine oil level and color since I am nearing the next change. This car has no significant or any oil consumption issues that I have noticed in my 5-years of ownership.
    Though the golden color looks similar at 6-month mark like the other oil brands I have used in the past, I have noticed some dirt that you can see on the hand towel.
    Does it look normal?
    I live in an extremely slow-moving urban area with often stuck traffic for hours. The average speed is only around 15 kmph so the engine idles a lot just to power the AC and charge the hybrid battery while sitting idle in bumper-to-bumper traffic.
  2. Leadfoot J. McCoalroller
    8,138
    7,642
    Pennsylvania
    2018 Prius c
    Dirt that comes out with the oil is better than dirt that stays in the engine.
    Maybe the stuff you're using now has a little more detergent than what you used before? Could also be a change in the fuel, since most of what you see is carbon left over from combustion.
    Doesn't look like a problem to me.
    PriusCamper and kamrul like this.
  3. BiomedO1
    BiomedO1 Senior Member
    4,105
    2,147
    SacTown, Ca
    Yes, more than likely sludge build up, assuming that stuff wasn't suspended in the new oil you put into it. Is that a full synthetic, synthetic blend, or regular oil? Full synthetic oil does a better job of keeping your internals clean. Think of it like plac build-up in your arteries, it'll eventually clog up your engine and damage it. Make sure a new, good quality oil filter is used on every oil change - that's what's going to catch that stuff. Make sure you've got a paper air filter, not that K&N sponge filter that lets in a lot of dirt and debris through.
    Good Luck...
    Havoline® Fully Synthetic Hybrid SAE 0W-20 1L | Caltex
    #3 BiomedO1, Dec 12, 2024
    kamrul likes this.
  4. Tombukt2
    Tombukt2 Senior Member
    13,362
    2,405
    Durham NC
    Flush the motor out one of these days or every two years or something they make chemicals you know and you can use various and sundry petrochemicals and just flush a lot of that nastiness out.
    kamrul likes this.
  5. ASRDogman
    ASRDogman Senior Member
    7,798
    3,978
    11 years and only 85,000 miles.
    You shouldn't have ANY sludge, at all. Unless you are NOT using synthetic oil.
    Which is what the Prius calls for.
    If that fancy oil is synthetic, perhaps the detergant is trying to clean out the regular oil.
    Are you using a Toyota Oil filter? You should. Do you change each time with the oil?
    Maybe someone threw sand in your engine?
    kamrul likes this.
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Take apart your oil filter at next oil change and check between the pleats if the same residu e are there. If so, could be that the air filter path has a crack just enough to dirt to enter engine after the air filter path.
    kamrul and ASRDogman like this.
  7. Kenny94945
    Kenny94945 Active Member
    857
    433
    Sausalito
    2016 Prius v wagon
    Dirt or sludge?
    I'd ask how would dirt get into the engine?
    Besides vandalism, I would look at your intake track and air filter.
    Perhaps a "dirty" gas station and the dirt is from fuel.
    Sludge, well, lack of oil changes or wrong oil.
    Cutting open an oil filter is a good suggestion from one of our co-members.
    Sending an oil sample to Blackstone Labs, or other, may be a valid option to determine.
    Good luck.
  8. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Is my name that offensive?! Muahahahahahah[/QUOTE]
  9. kamrul
    99
    17
    Bangladesh
    How difficult would it be to check for a potential crack after the air filter path? In case I find similar residue in between the pleats of the oil filter.
  10. kamrul
    99
    17
    Bangladesh
    I have been using Caltex Havoline 0W-20 Full Synthetic lately. I have used brands like Mobil 1, Liqui Moly etc. in the past. Always 0W-20 and well-known oil only.
    Unfortunately, contaminated and low-quality gasoline is a real thing around here. I have seen people suffering from contaminated gas shortly after refueling. Luckily enough, I have never had to face such drawbacks but I can't certainly say for sure that there has been zero contamination in the fuel that I take.
  11. Leadfoot J. McCoalroller
    8,138
    7,642
    Pennsylvania
    2018 Prius c
    Smoke test.
    disconnect something convenient on the intake side, temporarily adapt an appropriate hose onto that and supply smoke- from a purpose built machine, a theatrical smoke generator, or a nearby cigarette smoker.
    Then look for the smoke coming out anywhere it shouldn't in the path back to the filter box. Have good lights and record video for later review.
    I can't say I've noticed that product near me but I'd have no reservations about using it in our car.
    If this is your oil shortly before you are getting rid of it, then we are seeing it at its worst.
    I don't think you have anything to worry about based on that picture. But keep checking, take more pictures. Takes time to do it right.
  12. kamrul
    99
    17
    Bangladesh
    Always 0W-20 and new filter every time - OEM or similar paper-type filter.
    The funny thing though with the Liqui Moly 0W-20 is that it is a Group III base oil or Hydrocracked oil so they can't label it as Fully Synthetic because anything that is not at least Group IV can't be called Fully Synthetic in Germany. However, the same lube is sold with Fully Synthetic label in the USA market due to different regulations, I assume.
  13. kamrul
    99
    17
    Bangladesh
    I have always used 0W-20 and the label said, Fully Synthetic. Mobil 1, Liqui Moly, Caltex Havoline etc.
    By synthetic oil, did you mean fully synthetic or synthetic blend? I know, fully synthetic is better. Some oil that is labeled as Fully Synthetic use Group IV base oil, some others Group III. The regulations on whether a Group III can be called as Fully Synthetic varies from country to country it seems.
    Well, there are a lot of counterfeit Toyota OEM oil filters so I have had to only use OEM when I was sure about the source. Other times I used similar paper-type filters. A new oil filter every time I change oil.
  14. kamrul
    99
    17
    Bangladesh
    How difficult is it going to be to check thoroughly the intake? I'm going to my regular garage in a few days.
    In case it is due to bad fuel, do you think using a fuel system cleaner from Techron or similar could be highly beneficial?
    I have always used 0W-20, the label said, Fully Synthetic. Mobil 1, Liqui Moly, Havoline etc. The maximum duration I ever used any oil was around 8 months, usually around 6 months. Max run was 6,800 kms (~4,300 miles) but usually around 5,500 kms (~3,500 miles) on each interval. But it drives through a slow-moving urban bumper-to-bumper traffic so the engine idles quite a lot.
  15. BiomedO1
    4,105
    2,147
    SacTown, Ca
    Synthetic vs conventional oil
    You may also want to watch this too.
    The Motor Oil Geek - YouTube
  16. ASRDogman
    7,798
    3,978
    "OEM or similar paper-type filter."
    Stick with OEM.
    The fuel is different from the engine oil. The two never meet, except in the cylinder.
    So if fuel is getting into the engine oil, you have a serious issue. Which likely you don't.
    Make sure you are using ACTUALLY synthetic oil, not a blend, that is NOT synthetic.
    If you look at the maintainence book, I believe for your type of driving, adverse/extream conditions
    3000 miles is when you should change it.
    I actually don't think you have any issues with your oil. Engine oil get dirty.
    I have always used 0W-20, the label said, Fully Synthetic. Mobil 1, Liqui Moly, Havoline etc. The maximum duration I ever used any oil was around 8 months, usually around 6 months. Max run was 6,800 kms (~4,300 miles) but usually around 5,500 kms (~3,500 miles) on each interval. But it drives through a slow-moving urban bumper-to-bumper traffic so the engine idles quite a lot.[/QUOTE]
    kamrul likes this.
  17. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    A couple of things. When you switch from one brand of oil to another.
    The new brand may be better at pulling out different kinds of contaminants.
    Also, Before I change my oil, I always get the oil hot by driving on The highway for ten minutes. That way I know All the junk
    Is in suspension before dumping the old oil and I'll drain more of it.
    SM-A536V ?
  18. kamrul
    99
    17
    Bangladesh
    Just to be sure, do you mean PAO-based synthetic oil only?
