Disable Automatic Driver's-Side Window?
Discussion in 'Gen 2 Prius Main Forum' started by reddave, Jun 15, 2008.
  1. reddave
    reddave New Member
    Virginia
    My biggest pet peeve about the Prius is that it's difficult to simply crack my driver's side window -- pressing the window down button causes the window to start to go all the way down, so I have to "catch" it and, if it's gone too far, then I have pull the window up button and "catch" it again before it's gone all the way back up. Very annoying. Is there a way to disable the automatic window feature so that I can simply hold it down until it's as low or as high as I want it to be??
  2. Tchou
    Tchou Member
    161
    the button has two stages if you hit it only to the first one it will stop as soon as you stop pushing it...
  3. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    If you disconnect the 12V battery, it'll make you re-initialize the AUTO function on the window. As long as you don't go through the procedure to enable AUTO mode, the driver's side window will operate like the others. Take note that if you do disconnect the battery, you'll lose other saved settings, like radio presets and the time, and you'll need to reprogram those.
  4. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    Yeah, just ease your push or pull on the window button there Incredible Hulk. Then the auto feature won't kick in.
  5. chrisspaulding
    556
    24
    Kentucky
    I've disconnected my 12v and the auto window feature was still working when reconnected. Maybe a difference in the '08?
  6. Presto
    1,326
    24
    Vancouver, BC
    do not know. Perhaps someone could confirm that. I've known that every time i've worked on the electronics, I had to disconnect the battery, and then a whole bunch of stuff would be reset. Did you disconnect your battery for a brief moment or for a while?
  7. rsforkner
    rsforkner Member
    369
    Boynton Beach, FL, USA
    2014 Prius v wagon
    I have cursed that auto-down "feature" of driver's windows for years. I always regarded it as a design flaw instead of a "feature". The company I retired from often had several "features" on their equipment. Many of these were, in fact, design mistakes or unintended results of the design process.
    The Prius is the FIRST car I have seen that attempts to fix this "feature". I applaud Toyota for their efforts. While I would have eliminated it completely, the Prius solution is the best compromise I can think of, short of another switch to turn the auto-up/down feature on or off.
    FWIW department: The Prius is also auto-up. I never saw that before.
    Bob
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Be gentle grass hopper, it isn't a clunky old American car, it will respond to subtle inputs. Don't stab at the switch but lightly press it and when you release the window will stop.
  9. JEFNLSA
    JEFNLSA New Member
    29
    Phoenix AZ
    Nice...I was wondering the same thing. Thx for the "light touch" explanation.
  10. Tchou
    Tchou Member
    161
    For my part I never saw otherwise, in Europe if it's auto down it's also auto up, and it's also never only auto...
    On some french cars all windows have these two stage buttons and auto up/down feature...
    On the Prius it's only the driver's...
    the only thing I find strange in the prius but also in the toyota Yaris is when you lock the windows (the children lock on the driver's side),
    1- it also lock the front passenger window
    2- even the driver cannot manipulate the windows without unlocking first...
  11. stevecaz
    stevecaz New Member
    77
    Massachusetts
    I was wondering about this (don't have my Prius yet).
    Locking out all windows to the driver when the "kids" disable button is activated in INEXCUSABLE by Toyota engineers. That is a fairly simple electrical circuit. My other car that is 11 years old does it right. The car I sold to get the Prius did it wrong, and its one reason why I'm not buying the same brand.
    If you say big deal, then you don't have small children who will grab that brief opportunity of deactivation.
  12. brad_rules_man
    brad_rules_man Hybrid electric revolutionizer
    716
    76
    Effingham
    Yeah, I am surprised that they have it set up that way too, (windows not movable even by driver when locked.) However, I love the auto-up/down feature. I had a car that did that with all the windows previously and that was the bomb!
  13. darelldd
    6,059
    389
    Northern CA
    I've dealt with MANY cars that have this feature. In every case, it was not "auto only." All you have to do is realize that the switch is two-stage (like point and shoot cameras where you can focus by pushing half way). And suddenly it is a very desirable feature. I love it. Both auto up and down. Subtlety is your friend. This wasn't a "mistake" re-branded as a feature. It cost money to design and implement properly. Now all we have to do is train the drivers. ;)
  14. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    Hey, I have an idea. Why don't they just put a little crank handle on the inside of the door? That way we could eliminate the extra weight of the motors and all of that electronic wires and stuff. Better MPG.
    And, a little exercise never hurt anyone. Now that would be really cool...
    Bob
  15. patsparks
    10,664
    567
    By using electric windows it allows more flexibility of design throughout the cars interior because it's easier to locate switches than window winder handles.
  16. rsforkner
    rsforkner Member
    369
    2014 Prius v wagon
    1) I'm sure you understood that that suggestion was about 99% joke. No way do I want to go back to cranks. (Lord knows, there are enough cranks around already :D )
    2) While all you say is true, let's not forget why electric windows were offered in the first place, $$$$$$$. It was an option on high end cars to make money. I would guess that market pressure and to some extent manufacturing costs contributed to making electric the standard it is today.
    Side Note
    Back in the '70s my dad bought his first car with electric windows. He was so proud of them. One day he called me because they quit working. All four quit working at "exactly" the same time. He went to the dealer to get it fixed. Dealer told him that all four motors were bad. $140.00 EACH to replace. He decided to wait, thus the call to me.
    I went nuts! After I calmed down, I told him where to find the fuse and all was wonderful again. I sure wished I lived closer so I could have had a little "talk" with the owner of that dealership.
    <back to business>
    Bob
