disable nav safety?
Discussion in 'Gen 2 Prius Audio and Electronics' started by stinken1, May 7, 2005.
  1. stinken1
    stinken1 New Member
    is there a way i can disable the safety on the nav? so i can type while i drive?
  2. Hoagie
    Hoagie New Member
    59
    I saw a method of doing this a long time ago (I've been away from PriusChat for a while), so I couldn't point you in the right direction, but I know something, somewhere, exists.
    It is a small board that you have to splice into a wire (or two) somewhere that, in effect, tricks the nav computer into thinking you are going under 5 miles an hour. If I remember correctly, it tricks other systems into thinking the same thing and produces some weird results.
    Now, should you be tinkering with the nav screen while you are driving? If I'm the car next to you, I'd just prefer you pulled over at the next rest stop to fix your destination info. :wink:
  3. tag
    tag Senior Member
    2,526
    Chicago
  4. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Dave at Coastal Tech has a mod for the nav, but hasn't delivered yet. He is developing something for the bluetooth/info side of things.
    www.coastaletech.com
  5. hdpigott
    hdpigott New Member
    Victoria, TX
    Coastal Electronics purportedly sells a simple-to-install kit to accomplish what you want. I've had one on order for a couple of months, though. I think they are backlogged at the moment.
    http://www.coastaletech.com/04prius.htm
  6. plusaf
    plusaf plusaf
    324
    Raleigh, NC
    my http://www.plusaf.com/prius/prius.htm shows where i put my override switch. the directions are great, and it's really easy to do, except for breaking the one wire and putting the switch in series.... it's a bear to get to the wire!
    but it's less than an hour (half of which i spent struggling with the doggone wire... :guns: )
    but the safety point is well-taken: that switch is there for my passenger/co-pilot/wife to be able to access the Nav while i'm driving.
  7. stinken1
    stinken1 New Member
    has anybody had bad experience breaking the wire? example: nav malfunction?
