Disable passenger airbag on Prius 2010
Discussion in 'Gen 3 Prius Main Forum' started by chrisis, Mar 19, 2011.
  1. chrisis
    chrisis New Member
    breda
    Since it's horrid to fit a 'maxi-cosy' on the rear seats of my prius2010 (because the seatbelts don't give way once you let them go a bit) I want to install it on the passangersseat in the front... but to do that safely, I have to disable the airbag, and here's the problem... in any other car there is a switch in the glovecompartment, but in the priusIII this doesn't seem to be the case...
    can anyone tell me how I can disable the front-passengers seat airbag??
    thanks
  2. Mendel Leisk
    40,584
    What is maxi-cosy? Is that a child seat?
  3. chrisis
    chrisis New Member
    breda
    something like that... it's somewhat like a crib for when the child isn't able to sit on his own ...
    it's possible to fit this thing properly in a car using the seatbelt, but it's necessery to disable the airbag because the child is facing backwards
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I don't believe the passenger airbag can be disabled (legally). I know the dealers won't do it. It's much safer for the child to be in the back seat anyway. I think you're just going to have to fight with the rear seatbelt.
  5. chrisis
    chrisis New Member
    breda
    in ANY OTHER car I've driven, it was a simple switch in the glove-compartment...
    and... on the dashboard in front of the passengersseat is a symbol that indicates the airbag is either ON or OFF ... the indicator also shows a 'maxi-cosy' in that indicator to be sure you don't install a maxi-cosy with the airbag ON...
  6. firepa63
    1,761
    208
    Where are you located?
  7. vday
    vday Member
    312
    Israel
    On the European / Israeli model it is possible.
    Switch is on the side of upper glove compartment. I believe you can see it only with the door open and the you need the key in the FOB to do it.
  8. chrisis
    chrisis New Member
    breda
    I'll look right away, thanks vday!
  9. firepa63
    1,761
    208
    That option is not available here in the US...
  10. zdenok
    zdenok Junior Member
    57
    Bratislava, Slovakia
    RTFM next time?
    iPhone ?
    Zdenok
  11. PapaGallo
    PapaGallo Junior Member
    58
    22
    nj
    Hi Chrisis
    The system automatically detects whether its an adult or a child sitting on the front passenger seat, and disables the front passenger bags if detects a child on the front passenger seat.
    page 127 of the manual, and info if you need to put a child in the front seat on pages 134-135.
    good luck
  12. snijd
    snijd DIY or die
    243
    52
    PNW
    There IS an NHTSA process by which you may request to have such a switch installed.
    Since Toyota already makes this provision in some markets, it should be possible in the USA as well.
    Please report back if you are successful.
  13. firepa63
    1,761
    208
    I believe the OP is located in The Netherlands...
  14. snijd
    snijd DIY or die
    243
    52
    PNW
    should have caught that, since we moved here from there not so many years ago... was only dreaming of a Prius back then...
  15. Hang Zhao
    Hang Zhao New Member
    New Zealand
    This video from YouTube said the system will automatically detect whether the passenger seat has been occupied, then activate or deactivate passenger side airbag accordingly.
