Disable reverse beeper?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Nance, Jun 1, 2010.
  1. Nance
    Nance New Member
    Wisconsin
    Has anyone disabled the beeper when put into reverse on your 2010 model? I did it on my 2005 model very easily, but cannot find the steps to take for various changes on the 2010 models.
  2. JimboPalmer
    12,470
    6,869
    Greenwood MS USA
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    :welcome:. I recommend showing the Service Writer the pages in the manual. Pointing out exactly what you want done should make things go easier. It should also be free.
  4. Charlyc
    Charlyc Junior Member
    Long Island NY
    I printed the page that I needed from the PDF manual and brought in to the dealer and had him do it before delivery.
  5. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Make sure when you take it to the dealer to tell the technician to change the reverse beep from "continuous" to "single" and not to have the car door open when he tests it in reverse. If the door is open, putting the car into gear will produce a steady non-stop beep. I wasted 2 hours due to this.
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Only continuous or single beep. Cannot be shut off, as as possible on the generation 2.
