Disable reverse beeping generation 4?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Pete Sharp, Apr 2, 2016.
  1. Pete Sharp
    Pete Sharp Junior Member
    Washington
    The method for disabling the reverse beeping for previous generations doesn't work on the new/4th generation. Does anyone know the secret? How about disabling the beep from locking/unlocking the car with remote?
  2. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    I got the Carista app and adapter, which enables you to do that and many other things from your iPhone.
    Kasper and glennonrp like this.
  3. TeachingMaroon
    TeachingMaroon New Member
    San Diego, Ca
    Where do I buy the adapter and is it easy to install myself or I have to get it installed? Any idea on how much it will cost?
    iPhone ?
  4. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Mambo Dave likes this.
  5. TeachingMaroon
    San Diego, Ca
    Thanks! I'm buying it now. :)
    iPhone ?
  6. Jim in NC
    Jim in NC Active Member
    217
    266
    28
    Myrtle Beach, SC
    John does your carista allow you to modify all the settings in pages 753-758 in the owner's manual?
    I'm specifically looking to activate the keyfob open of the power windows.
    Also does it show any other interesting info about the car? thanks.
  7. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    Jim, ucla107 kindly posted the listing of everything Carista will do on the Gen 4. It's in post # 10 of the following thread:
    Any carista users on gen 4? | PriusChat
    It looks as though it will do what you want with the windows.
    It will also check for codes and cancel them if you want.
  8. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    Why don't the Toyota engineers read this forum. Beep outside the car so people can run and loud enough you can hear it inside.:ROFLMAO:
    And an audio saying deaf/blind old man backing up. Run Forest run.
    #8 ETP, Apr 9, 2016
  9. TeachingMaroon
    San Diego, Ca
    Yay! No more beeping when reversing!
    krmcg likes this.
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    We refuse to write in Japanese.
  11. Beezybone
    Beezybone Junior Member
    34
    22
    Murrieta
    2020 Prius
    What else can the app do to the gen 4 Prius?
  12. David9962000
    David9962000 Member
    139
    66
    2020 Prius
    It's listed on their website. Select your vehicle then click on customization sample.
    I have it and I did:
    Reverse beep
    lowered the sound of the parking sensors one notch
    Turned off the rear seat belts chime so I could put a bag on the backseat without a beep. I left the fronts on since I wear them and they're speed sensitive not timed.
    Beezybone likes this.
