Disable seatbelt beep.
Discussion in 'Gen 3 Prius Technical Discussion' started by Jonathan Ciaccio, Jul 30, 2014.
  1. Jonathan Ciaccio
    Jonathan Ciaccio Junior Member
    Hey Folks. Does anyone know how I can disable the seatbelt beep on my 2010? I have OBDII scanner and enginelink but I cant find any PIDs about seatbelts.
    And before anyone says it's dangerous, Im doing this for two reasons
    1) I drive around a lot at about 15 MPH. That's why I got the 2010 with EV mode. And I dont always want to click on my seatbelt.
    2) I load things in my front passenger seat which triggers it all the time.
    Thanks for the help.
  2. Shin Chan
    Shin Chan Junior Member
    56
    Sacrameto, California
    You need to use a scanguage not an obd-II. There are a few how to videos on YouTube. The most helpfully how to video i found was from a guy working on his diesel truck.
  3. sushi1026
    sushi1026 107mpg
    69
    31
    35
    New Jersey
    You can use the attached PID. In case you want to disable the reverse beep too I've attached that PID as well. I didn't disable my seatbelt but did disabled my reverse beep. Also disclaimer I have a PiP, but I don't think it's any different.
    MrKite and 7-0-SAV like this.
  4. FrankB
    FrankB Member
    117
    53
    I used the instructions here to change the beeping to a single beep.
  5. qdllc
    qdllc Senior Member
    1,370
    399
    Would it be smarter to just disconnect the sensor in the passenger seat that triggers the alarm? I'd not recommend you drive without your seat belt...period.
  6. testuserER
    testuserER Guest
    The worst injuries are often caused by ANOTHER vehicle........and you can get thrown around pretty bad just at 15 MPH......AND the air bags can actually make matters WORSE without the seat belt in use.
    So, I too encourage you to use your seat belt EVERY time you move the car more than 50 feet or so.
    What happens on the passenger side if you latch the belt with nobody in the seat ??
    qdllc and Jon Hagen like this.
  7. qdllc
    qdllc Senior Member
    1,370
    399
    Very good idea. I've known people to do that on the driver's side to avoid the buzzer. :eek:
